Check out my PDU encoder software
samson A.
Member level 3
Lagos, Nigeria
hi guys whoever is interested can download my pdu encoder software. simply type message(sms) in the text box enter the sms center number, receiver number and the sequence number and then generate the hex data required to send this message. declare this as a character constant in your mcu code and off you go. if you wanna test the hex output before programming the MCU, connect the mobile phone to your pc and select its serial port. wait for "not connected" to change to "connected", then press send button. support nokia 3310, 5110..... but tested ok with 5110. thanks
