Check my frequency meter design
pic-novato
Member level 2
Lima - Peru
Hi
I built this frecuencimeter, but the input stage is very simple, i can`t adjust for diferent values of Frecuency, have somebody a better diagram.
Thanks in advance
Borber
Advanced Member level 5
on third flor
frecuencimeter pic 16f84a
This input stage is enabling you to measure frequencies up to about 50MHz. Sensitivity is about 0.1Vpp. What is your problem?
pic-novato
Member level 2
Lima - Peru
test prescaler circuit
Hi Borber:
I try to adjust the x point to 5 v, but can't do it, only 4.2 v. I change for 1000 ohms preset.
I use this circuit to measure square signal, i built a circuit to give me signals from 1 Hz to 20 Mhz. But when i adjust the preset to read low frecuency (> 1 KHz) i can't read hi frecuency, and when i adjust for read hi frecuency (< 5 MHz) can't read low frecuency.
I can measure square signal with this input stage?
And i looking for a stage to 1 GHz using a prescaler.
Thanks
Borber
on third flor
frecuencimeter projects
Change 470pF capacitor to 100pF.
Input stage up to 1GHz has no sense.
pic-novato
Member level 2
Lima - Peru
frecuencimeter pic
Thanks Borber, i will change the capacitor and test it.
Why you think has no sense put a prescaler in the entrance?
Please take a look this circuits. I know its a 64 or 256 prescaler, but i will modify the program.
Borber
on third flor
frecuenciometer
Sory, I missed the word prescaller. Of cause it makes a sense to use it.
hermin
Full Member level 2
diagram frecuencimeter
I wanna ask something, if you simulate this circuit on electronic workbench, would a frequency sweep be a useful tool in checking the input stage of the device?
anthony123
Newbie level 1
frekuenzmeter
Hi.. i'm writing from Venezuela.:! I've a little ask.. ¿Anybody of you has make a good frecuency meter that can measure low frecuencys (1-30000 Hz) until some one high like 5 Mhz?
