cadenceUK
Member level 5
Check my code for the ber vs eb/no calculation & plotting for QPSK,QAM,16 QAM,64 QAM
i have to make programs for qpsk,qam,16 qam,64 qam,and calcualte the ber vs eb/no and plot them.
i have made some programs which im also sending see if u make cahnge and corect them.
#include<stdio.h>
#include<stdlib.h>
#include<conio.h>
#include<math.h>
#define N 2000
#define block_size 2
#define amplitude 1.414
void modulate_encoder(int,int,float trans_code[],int);
void demodulate_decoder(float,float,int decode_values[],int);
void gaussian_noise (float sigma,float *nre,float *nim);
void channel(float trans_real[], float trans_imag[],float snr,float received[]);
int error_count(int code_packet[],int decode_values[]);
// channel function with added white gaussian noise have power of specific snr.
//void channel(float trans_real[],float trans_imag[],int N,float snr,float received_real[],float received_imag[]);
float gen_sigma(float snr);
// random number generator
long int rran(long int seed);
long int rran2(long int seed);
void main()
FILE *perfQPSK;
int bits[N];
float trans_real[block_size/2],trans_imag[block_size/2];
float rectrans_real[block_size/2],rectrans_imag[block_size/2];
float trans_code[block_size];
int recdecoded_bits[block_size];
int decode_values[block_size],accum_errors,errors,block;
int i,j;
int code_packet[block_size];
double Pb;
float snr=2;
float nre,nim,Eb_No,received[block_size]; // for noise of the channel
int decoded_bits[20],inter_length=2;
if((perfQPSK=fopen("perf_QPSK.txt","w"))==NULL)
printf("\n unable to open the file\n");
for(i=0;i<N;i++)
bits=rand()%2; // generates '1' or '0'
for(Eb_No=0;Eb_No<100;Eb_No=Eb_No+5) //in dB
accum_errors=0;
block=0;
for(i=0 ;i<N; i=i+block_size)
for(j=0;j<block_size;j++)
code_packet[j]=bits[i+j];
for(j=0;j<block_size;j=j+2)
modulate_encoder(code_packet[j],code_packet[j+1],trans_code,j);
trans_real[j/2]=(amplitude/1.414)* trans_code[j];
trans_imag[j/2]=(amplitude/1.414)*(trans_code[j+1]);
channel(trans_real, trans_imag,snr,received);
for (j=0;j<block_size;j=j+2)
rectrans_real[j/2]=received[j];
rectrans_imag[j/2]=received[j+1];
demodulate_decoder(rectrans_real[j/2],rectrans_imag[j/2],decode_values,j);
recdecoded_bits[j/2]=decode_values[j];
recdecoded_bits[(j/2)+1]=decode_values[j+1];
errors = error_count(code_packet,recdecoded_bits);
accum_errors += errors;
block++;
Pb=(double)accum_errors/(block*block_size);
//calculate BER probability
printf("Eb_No=%0.1f\t%d blocks\tBER=%0.25lf\n",Eb_No,block,Pb); //output string to screen
perfQPSK=fopen("perf_QPSK.txt","a"); //open a file
fprintf(perfQPSK,"Eb_No=%0.1f %d blocks BER=%0.20lf\n",Eb_No,block,Pb); //write string to file
{// This is the channel where the noise is added to the modulated data.
int i;
float nre,nim;
//AWGN channel
for(i=0;i<2;i+=2)
gaussian_noise(gen_sigma(snr),&nre,&nim);
received = trans_real[i/2] + nre;
received[i+1]=trans_imag[i/2]+nim;
float sigma;
sigma = sqrt(1/(2*powf(10,snr*0.1)));
return sigma;
//Gaussian number generation
float r,v1,v2,f,ran1,ran2;
r=1;
while (r>=1)
ran1=rran(0)/pow(2,30);
ran2=rran2(0)/pow(2,30);
v1=2*ran1-1;
v2=2*ran2-1;
r=pow(v1,2)+pow(v2,2);
f=(float) sqrt(-2*pow(sigma,2)*log(r)/r);
*nre=v1*f;
*nim=v2*f;
void modulate_encoder(int localbit1,int localbit2,float codevalue[], int i)
if(localbit1==0)
codevalue=1;
else
codevalue=-1;
if(localbit2==0)
codevalue[i+1]=1;
else
codevalue[i+1]=-1;
void demodulate_decoder(float local_receive_real, float local_receive_imag,int decode_values[], int i)
if(local_receive_real>0)
decode_values=0;
else
decode_values=1;
if(local_receive_imag>0)
decode_values[i+1]=0;
else
decode_values[i+1]=1;
int error_count(int trans_code[],int decoded_bits[])
int i,dec_errs,inter_length=2;
dec_errs=0;
for(i=0;i<inter_length;i++) /* number of errors after decoding are counted. */
if(trans_code != decoded_bits)
dec_errs++;
return(dec_errs);
#include<stdio.h>
#include<conio.h>
#include<stdlib.h>
#include<math.h>
void modulate_encoder(int *localword,float * codevalue);
void demodulate_decoder(float local_receive_real, float local_receive_imag,int *decodevalue, float amplitude);
void main()
//clrscr();
int bits[20],info_word[4];
float trans_real[5],trans_imag[5],A;//, received_real[10],received_imag[10];
float trans_code[2];
int decode_values[2];
int decoded_bits[20];
int i,j, local_bitval, N;
float snr=2;
float nre,nim; // for noise of the channel
printf("The number bits must be less than 20 and multiple of 2");
printf("\nEnter the total number of bits to be encoded:");
scanf("%d",&N);
printf("\n Enter the basic amplitude of the QAM modulation:");
scanf("%f",&A);
if(!((N%4==0)||(N<=20)))
printf("The number that entered is not a multiple of 4 or not less than 20");
scanf("%d",&N);
printf("Enter the bits to be encoded");
for(i=0;i<N;i++)
scanf("%d",&local_bitval);
bits=local_bitval;
for(i=0;i<N;i=i+4)
for(j=0;j<4;j++)
info_word[j]=bits[i+j];
modulate_encoder(&info_word[0],& trans_code[0]);
//printf("\nreal value %f , imag value %f \n", trans_code[0],trans_code[1]);
trans_real[i/4]=trans_code[0] * A;
trans_imag[i/4]=(trans_code[1])* A;
int i;
float nre,nim;
//AWGN channel
for(i=0;i<inner_interleaver;i++)
received = code_packet + nre;
float sigma;
return sigma;
AWGN channel
for(i=0;i<N;i=i+2)
received_real[i/2] = trans_real[i/2] + nre;
received_imag[i/2] = trans_imag[i/2] + nim;
for (i=0;i<N;i=i+2)
printf("\ncoded values: %f\t %f \n received values: %f\t %f \n\n",trans_real[i/2],trans_imag[i/2],received_real[i/2],received_imag[i/2]);
for (i=0;i<N;i=i+4)
demodulate_decoder(trans_real[i/4],trans_imag[i/4],& decode_values[0], A);//received_real[i/2],received_imag[i/2],& decode_values[0]);
//printf("\nvalues %d and %d",decode_values[0],decode_values[1]);
decoded_bits=decode_values[0];
decoded_bits[i+1]=decode_values[1];
decoded_bits[i+2]=decode_values[2];
decoded_bits[i+3]=decode_values[3];
for(i=0;i<N; i=i+4)
printf("The boolean value of bits: %d %d %d %d \nThe encoded value %f +j %f\n\n",bits,bits[i+1],bits[i+2],bits[i+3],trans_real[i/4],trans_imag[i/4]);
printf("\nThe encoded bit stream of inphase :");
for(i=0;i<N;i=i+4)
printf("%f ",trans_real[i/4]);
printf("\nThe encoded bit stream of quadrature :");
for(i=0;i<N;i=i+4)
printf("%f ",trans_imag[i/4]);
printf("\nThe decoded value of bits:");
for(i=0;i<N; i=i+4)
printf("%d %d %d %d ",decoded_bits,decoded_bits[i+1],decoded_bits[i+2],decoded_bits[i+3]);
float sigma;
return sigma;
r=1;
while (r>=1)
v1=2*ran1-1;
v2=2*ran2-1;
*nre=v1*f;
*nim=v2*f;
void modulate_encoder(int *localword,float *codevalue)
printf("To check the number of time the finction called\n");
// inphase component generation
if ((*(localword)==0) & ( *(localword+1)==0) )
*codevalue=1/1.414;
else if ((*(localword)==0) & ( *(localword+1)==1) )
*codevalue=3/1.414;
else if ((*(localword)==1) & ( *(localword+1)==0) )
*codevalue=-1/1.414;
else if ((*(localword)==1) & ( *(localword+1)==1) )
*codevalue=-3/1.414;
//quadrature component generation
if ((*(localword+2)==0) & ( *(localword+3)==0) )
*(codevalue+1)=1/1.414;
else if ((*(localword+2)==0) & ( *(localword+3)==1) )
*(codevalue+1)=3/1.414;
else if ((*(localword+2)==1) & ( *(localword+3)==0) )
*(codevalue+1)=-1/1.414;
else if ((*(localword+2)==1) & ( *(localword+3)==1) )
*(codevalue+1)=-3/1.414;
void demodulate_decoder(float local_receive_real, float local_receive_imag,int *decodevalue, float A)
*decodevalue=0;
if(local_receive_real>A*(1.414))
*((decodevalue)+1)=1;
else
*((decodevalue)+1)=0;
else
*decodevalue=1;
if(local_receive_real<A*(-1.414))
else
*(decodevalue+2)=0;
if(local_receive_imag>2.828)
*((decodevalue)+3)=1;
else
*((decodevalue)+3)=0;
else
*(decodevalue+2)=1;
if(local_receive_imag<-2.828)
else
#include<stdio.h>
#include<stdlib.h>
#include<conio.h>
#include<math.h>
#define N 2000
void main()
FILE *perfQPSK;
int bits[N];
int i,j;
double Pb;
float snr=2;
for(i=0;i<N;i++)
accum_errors=0;
block=0;
block++;
int i;
float nre,nim;
//AWGN channel
for(i=0;i<2;i+=2)
float sigma;
return sigma;
r=1;
while (r>=1)
v1=2*ran1-1;
v2=2*ran2-1;
*nre=v1*f;
*nim=v2*f;
if(localbit1==0)
codevalue=1;
else
codevalue=-1;
if(localbit2==0)
codevalue[i+1]=1;
else
codevalue[i+1]=-1;
decode_values=0;
else
decode_values=1;
else
dec_errs=0;
dec_errs++;
return(dec_errs);
#include<stdio.h>
#include<conio.h>
#include<stdlib.h>
#include<math.h>
void main()
//clrscr();
float snr=2;
scanf("%d",&N);
scanf("%f",&A);
scanf("%d",&N);
for(i=0;i<N;i++)
bits=local_bitval;
for(i=0;i<N;i=i+4)
for(j=0;j<4;j++)
int i;
float nre,nim;
//AWGN channel
float sigma;
return sigma;
AWGN channel
for(i=0;i<N;i=i+2)
for (i=0;i<N;i=i+2)
for (i=0;i<N;i=i+4)
for(i=0;i<N; i=i+4)
for(i=0;i<N;i=i+4)
for(i=0;i<N;i=i+4)
for(i=0;i<N; i=i+4)
float sigma;
return sigma;
r=1;
while (r>=1)
v1=2*ran1-1;
v2=2*ran2-1;
*nre=v1*f;
*nim=v2*f;
*codevalue=1/1.414;
*codevalue=3/1.414;
*decodevalue=0;
else
else
*decodevalue=1;
else
*(decodevalue+2)=0;
else
else
*(decodevalue+2)=1;
else
