Check my code for interfacing PC with a 8051
hot_ice
Member level 1
Hi every1!!!
well frndz, i'm given a task of interfacing PC with a 8051 µC (of course using serial port). on the PC i'll be developin a GUI which will probably have 3 (or more) toggle buttons as i press a button the FAN, BULB or TUBE_LIGHT attached with the µC turns off or on. i'm not good @ programmin. anywayz i've wriiten a code... plz chk it n let me know if there r any errors...
ORG 0
LJMP MAIN
ORG 23H
LJMP SPISR
ORG 30H
MAIN:
CLR P2.0
CLR P2.1
CLR P2.2
MOV R1,#00000000B ;turn fan off
MOV R2,#00001111B ;turn bulb off
MOV R3,#01010101B ;turn tube-light off
MOV R4,#11111111B ;turn fan on
MOV R5,#11110000B ;turn bulb on
MOV R6,#10101010B ;turn tube-light on
MOV TMOD,#00100000B
MOV TH1,#-3 ;baud rate==9600
SETB TR1
MOV SCON,#01010000B
MOV IE,#10010000B
SJMP $
SPISR:
MOV A,SBUF
CJNE A,R1,L1
CLR P2.0
L1:
CJNE A,R2,L2
CLR P2.1
L2:
CJNE A,R3,L3
CLR P2.2
L3:
CJNE A,R4,L4
SETB P2.0
L4:
CJNE A,R5,L5
SETB P2.1
L5:
CJNE A,R6,L6
SETB P2.2
L6:
CLR RI
RETI
END
i've done with the schematci part... just chk the code... the scheme is when a user press a button to turn fan on... a code from pc is transferred to the µC... plz chk it... THX!!!
Re: chk this code...
If you posted code so it could be read, I bet more people would help. Try using the code tag.
Personally, I don't review people's code, especially student code. That's what debugging is about.
There are no errors in your code.
If you're going to use more, watch out to R7 bank0 and subsequent R0-R7 from bank 1 and the default value of SP after reset.
