electronicsandbooks
i am looking for the adjustment info of a Chauvin Arnoux 6412 ground tester. There are only 3 adjustment points to be seen. How and which values. Its not in the operating manual.
by 'adjustment points ' , which points are you referring in the tester ?
Dear Customer,
I confirm you that we cannot communicate the manual for calibration of the CA6412.
Our Service company, Manumesure, is able to do the calibration of the instruments.
You can contact Ms Florence Deterpigny (in copy of this email) to have more information about the costs of calibration for the clamps which need to be adjusted.
Best Regards,
Dear M , Contrary to the actual Earth Clamps (CA6416/6417), you cannot do the adjustment of the
CA6412 yourself. Unfortunately, I cannot communicate the calibration manual. However, thanks to the calibration loop for example, you can calibrate your instruments to check if an adjustment is necessary or not. So I invite you to check first and to come back to me with the quantity of clamps that you need to adjust. Best Regards,
fine support from this company
