Jester
Full Member level 6
- Joined
- Aug 18, 2012
- Messages
- 377
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Activity points
- 4,754
I searched and read applicable previous posts regarding chassis ground.
I found this comments from Dickfreebird useful: "A metal chassis is a huge antenna and you may pick up an extra amount of electrical noise in your signal ground if you tie them hard. The chassis only needs to be at a man-safe potential and the rest of it you'd rather not "see".
Circuit image to aid discussion:
1) So, it sounds like if you have a PCB in a metal chassis, best practice is to earth ground the metal enclosure (chassis), but not connect earth to the circuit on the PCB?
2) If the circuit board is in a non metallic (plastic) enclosure, is there any reason to introduce chassis ground to the circuit (either on the primary or secondary side?)
3) Seems common practice to connect the low voltage circuit ground to chassis (earth) either directly or via a R-C network, is there any reason to do this in a plastic enclosure?
a) I seem to recall the the creepage distance and possible HI-POT tests voltages are relaxed when the low voltage side is referenced to earth.
b) It seems like the low voltage circuit will/can float to any voltage if not referenced to earth.
