Hobbyer
Newbie level 2
charging ultracapacitors
Can a capacitor be charged, without damage, with a voltage higher than it's specified voltage, if the charging is stopped when the capacitor has reached it's specified voltage?
Here is the situation:
I have an ultracapacitor:
140 Farad, 2,5 Volt, ESR 7,2 mOhm, Leakage current 0,1 mA, Short circuit current 500 A
Then I have a solar cell matrix:
20 Volts in full sunlight, 5 volts with just my room light. About 2 Watts power in sunlight and in room light in the milliwatt range.
Goal: I want to charge the capacitor with the solar matrix with very little wasted power.
I could use a linear regulator, but that would waste power and my linear regulator did not get enough power in roomlight to even start regulating anyway.
Another way would be to use a switching regulator, but I did not have enough current for the one I had also.
Yet another way would be to construct a sort of charger, that would charge a smaller 35V capacitor to 2.5 volts and then pump it into the Ultracapacitor, but I was thinking if I could do it simpler way if it was possible:
Thing is that the capacitor can drain more power than the solar cell matrix can provide, so the voltage across capacitor will show the capacitor voltage or slightly above it (only tested with a 3300 uF, 35V capacitor). Therefore I thought that it _might_ be safe to charge with 20 Volt solar matrix, until the voltage across capacitor has reached 2.5 Volts.
This way I could also charge the cap faster, because the capacitor charging curve would be based on the higher charge voltage.
Problem is can this be done without destroying the capacitor (and maybe causing severe collatelar damage) assuming that I can reliably stop charging at 2.5 Volts.
I've looked for an answer for a long time, but I could not find any. Also I did not want to try out and risk destroying the capacitor, since I only have a handful.
