Charging of battery (12V or 24V) by solar panels.
shahbaz.ele
Advanced Member level 1
Islamabad, Pakistan
dear all
I want to made solar charging system ither for 12V or 24V battery.
actually i am trying to run load of my home at batteries charged through solar panels.
I have two solar panels
20Watt
5Watt
jiripolivka
Advanced Member level 5
Santa Barbara
dear all
20Watt
5Watt
Pity you give no technical details, not on your solar panels, nor on batteries.
A typical solar panel can generate 12 -15 V DC, and with it you can charge any battery. If it is a lead-acid battery, you can use a power resistor, 1...4 Ohms, 10-50 W, to measure the charging current. You also should measure the battery voltage, and stop the current if the voltage exceeds 13.8 V (~14V). Be sure you know good specifications of other batteries. Many are sensitive to overvoltage and overcurrent.
The "20W" solar panel is able to deliver a larger current to the battery while the "5W" panel will rather "trickle-charge" the battery.
You can google many professional battery chargers and solar-panel regulators, or you can experiment yourself. Make sure you have a good volt and ammeter and try it!
shahbaz.ele
Islamabad, Pakistan
sorry for late response.
there is no rating written on panels.
the seller said its 150 watt solar panel that gives 12V output.
how to check its current and wattage also.
tpetar
Pancevo-Belgrade, Serbia
Solar panels must charge batteries over solar charger regulator. Each solar panels have manufacturer specification for max OC voltage and max current. Usualy 12V panel have voltages 17-19V OC (better panels).
That panel of 150W should be around 8A.
tpetar
I already give you answer. Connect solar panel over charger regulator. This will eliminate situation of battery overcharging.
tpetar
sorry dear I do not know about over charger.
can you explain a bit about it.
Its charger regulator, this device regulate voltage given to battery. Regulator receive higher voltage from solar panels, regulate and give to battery voltage in safe range for battery and needed for charging.
Solar panel ---> charging regulator <---> battery
shahbaz.ele
Islamabad, Pakistan
ok I heard it here from some one
its popular name is charge controller here.
thanks dear i will search it in markeet.
tpetar
  • !!! Solar Charging Regulator 15A LM358.rar
  • !!! Solar Panel controller 12F675.rar
  • !!! Solar-charged battery regulator.rar
