[SOLVED] Charging not rechargable lithium battery
M
monkeyman160
Charging lithium battery
Do anyone know how not rechargable lithium battery behaves when it's charged?
Of course now someone writes that you shouldn't charge that kind of batteries but I think that there is no way to prevent that. There is always some kind of leagage currents (for example with diodes). And when expected lifetime of the device is long enough the charging amount may be quit significant.
What I know is that the charging amount should not exceed 3% of nominal capacity of the battery (with coin type batteries) over the lifetime. But what I don't know is what will happen when that is exceeded? I quess that the capacity of the battery will drop but how much? How quick?
Do anyone have some material of this topic?
Please help!!!
mr_ghz
Full Member level 5
Hi monkeyman160
As far as I know it is critical if your "charging" current is higher than about 1/1000 of the capacity. The cell will got hot and can explode...
I've never heard that the leakage current of a diode (less than some uA) has caused such problems.
Bye
