Charging large capacitor(1F) in hspice/cadence
Wanoz
Junior Member level 1
I have a charge pump whose output is connected large capacitor e.g. 1F, 2F with 4 stages, stage capacitor 250pF and supplying .6V. If it is like 10nF, it is easy to monitor charging of the charge pump by running simulation in hspice. However, large capacitance at the output takes long time charging and I don't know hspice allows to do that.
My question is that is there any way to charge large capacitance quick and efficient way without introducing initial value? Also, which simulations should be suitable to run the charge pump with large capacitance at the output?
Thnx.
FvM
Super Moderator
Staff member
Bochum, Germany
I wonder if the circuit has any practical use. It will take really a long to time to charge in real life, so in simulation. If finding .IC values by trial and error is too inelegant, you can spend your time in designing a behavorial precharge circuit. Not sure which approach will succeed faster.
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
When I want to rapidly charge a large capacitor, I create a separate high voltage source. It can be a pulse train, through a series diode and low ohms, applied to the cap.
Reactions: Wanoz
    Wanoz
