Charge Collecting Antenna fixing using Astro & Hercules
rakeshnunna
Member level 4
antenna fixing
Hi everybody,
I am trying to do Antenna Fixing at chip level using Astro and Hercules.I did the
antenna fixing using jumper insertion and diode insertion and some Antenna violation
got cleared. Astro's internal engine dont see any more Antenna vioaltions after that
but Hercules does. I am trying to import Hercules Antenna report into Astro to fix the
errors.Can anyone explain exactly how to import Hercules Antenna Report into Astro.
Note: I tried searching in solvenet and usermanuals but that didnt help
jackson_peng
Full Member level 2
Shanghai, China
charge collecting antenna
actually, i faced this problem last month.
you've to modify you hercules runset, following the userguide in hercules reference manual on DRC/ERC..
if you still have problem... you can mail me for the detail script modification...
