Characteristic of toroidal required for inductor design?
onemilimeter
Member level 3
What are the required characteristics/parameters/properties of the toroidal for inductor design? Thanks.
flatulent
Advanced Member level 5
Middle Earth
The material type will give you the losses at your frequency range.
The size will give you the power handling capacity.
The A sub L value will tell you how many turns to use to get your required inductance.
Then the flux saturation value will tell you the maximum DC current or peak AC current that it will handle. Gapped cores are better for DC currents.
VVV
I am assuming you are designing a powdered iron core inductor for a switching power supply.
Basically you start from the required DC current and the required inductance. That will give you the energy the core needs to store. You then select a toroid that can store that energy. To obtain the inductance, use the AL of the core and calculate the number of turns. Note that the inductance will swing, depending on the saturation ratio. Take that into account, although this is generally a desirable effect, since the inductance is higher at low currents, allowing operation in continuous current mode down to lower currents.
Select wire size based on the DC current. Check the turns will fit in the toroid. Else, either select a larger core or thinner wire.
Calculate the total losses: core + DC. Check temperature rise and make sure it is below 40C (lower is better, since cores age).
If it's too high, you need to redo the selection.
Go to the Micrometals website and check it out. They also have software that will do the calculations for you. https://www.micrometals.com/
Magnetics Inc. offer their Kool Mu cores. Check out their website for design guides. **broken link removed**
