I finally got my LCD working and now I can write anything to the LCD.
For next step, I am trying to put the value of ADC0 to LCD
I an able to get the ADC running and have verified it by putting the output to LED's on Port B. The LCD is connected on PORT D (data) and Port A (Control 1-3)
Now problem is that I am not able to tranfer ADC value to LCD. I think I am having some problem in Char to function tranfer. The code compiles fine, so I cannot debug it.
My MAIN code is
unsigned char val0;
while(1)
val0 = ReadAdcChannel(0);
lcd_goto(0); // select first line
lcd_puts(val0);
PORTB=val0;
If you need to format an integer or float value to send to a display, you can use the sprintf function that is defined in stdio.h.
Example:
#include <stdio.h>
void display_value(void)
unsigned int value = 22;
char buffer[16]; /* size of line on display */
sprintf(buffer, "Value is %d", value); /* Same formatting options as printf */
display_line(buffer); /* Your call to display function */
If you look at the character map of your display, you will find that 'T' is represented as the 8 bit number 0x54. This is the ascii code for 'T'.
The ascii code for the number 0 is 0x30 and for 1 it is 0x31. So if you take a digit and add 0x30 to it you get the ascii code for the digit.
a = 0x30 + 1;
lcd_puts(a); will display 1.
You need to convert your ADC reading value to ascii codes to display it on the lcd.
sprintf does this for you with formatting options.
a = 0x30 + 1;
It depends on what compiler you are using.
But they should all support the basic options.
d, i Print an int as a signed decimal number.
u Print decimal unsigned int.
f, F Print a double in normal (fixed-point) notation.
x, X Print an unsigned int as a hexadecimal number. 'x' uses lower-case letters and 'X' uses upper-case.
o Print an unsigned int in octal.
s Print a character string.
c Print a char (character).
You are asking it to print a char? %c
Ask it to print a unsigned int. %u
