channel coding in wimax
yasiranwar86
Junior Member level 2
wimax channel coding
channel coding in wimax:we r dong our final year project need help plz reply if any body can help
rmreddy
Member level 3
wimax channel coding standard
can you brief, what exactly is channel coding in WiMax ...
cwjcwjcwj
Full Member level 5
coding wimax
Have a look on Turbo codes and LDPC codes.....I guess this is what going to put in the WiMax product as for channel coding
sameerbabu
Member level 3
wimax profile channel
can u give some implementation details???
nawabumar
channel coding for wimax
aren't you that teeli guy from uet.lol.anyway man state your question like dr salim tariq always tells us to.
ekh_81
Newbie level 6
avinash 802.16 iitd
try ti use iy may be helpful
http://www.cse.iitd.ernet.in/~avinash/Final_Submission/OFDM_PHY/
yasiranwar86
i m going to implement viterbi decoder can any body help
fm_com_28
Full Member level 1
Fayoum, Egypt
wimax channel coding codes
I am also implementing the Viterbi Decoder,if u need any help
yasiranwar86
dr. tareq salim(wimax )
ya ineed plz i want c code of viterbi decoder
azim.fahad
coding in wimax
Hi yasiranwar and fm_com_28, first of all I have little reservation about the title of your FYP projects if u r only going to implement viterbi decoder coz as per IEEE 802.16-2004 (Section 8.3.3) and IEEE 802.16e –2005 standards The channel codec for WiMAX is always implemented either by "Concatenated Reed-Solomon-Convolutional code (RS-CC) or by use of Turbo code....
Now if u opt the RS-CC and implementing CC as an intermediate part..... then 1st of all develop native code rate ½ Convolutional coder with constraint length 7 and generator polynomials codes (G1, G2) equals to (171 OCT, 133 OCT). (as per IEEE standard 802.16-2004 Para 8.3.3.2.1).
In next step try to acheive the various code rate CC(mentioned in the table of IEEE standard 802.16-2004 Para 8.3.3.2.1 ) by puncturing(puncturing pattren availabe in IEEE standard 802.16-2004 Para 8.3.3.3) the 1/2-rate coder.......
xakker
Member level 2
generator polynomial wimax
viterbi is a decoding technique and can b used in addition to any channel coding technique
