[SOLVED] changing voltage for LDO
Paul GRIM
Junior Member level 1
Hi all,
I use this LDO in my design for filtering low frequency output noise.
I would like to change the output voltage of this LDO by the DAC.:drevil:
The output of the DAC range (0-3.3V)
The output of the LDO range (0-10V)
Have you an idea how i can design this ldo ?
Thank you for your help !
Paul
The feedback pin will servo to a certain internal reference value, usually 1.23V or 0.8V for low voltage types.
Wat you could do is to compare the a third of the LDO output (10 / 3 = 3.33...) to the DAC output with an opamp comparator, and then send this signal to the feedback pin instead. A low noise, rail to rail opamp like the LMV321 is recommended.
Hi ArticCynda,
thanks for your answer
the internal reference of this ldo is 1.25V typ
Can you clarefy your idea please !
this is my shematic !
Paul
hi
i underestand your idea
Paul
Glad I could help, good luck!
If your problem is solved, please don't forget to mark the thread as [solved].
