Re: SPI help needed .....
The SS pin is only used when the device is a slave. But you need to configure the device as a slave. The SS pin must be configured as Slave Select on the slave, but it will be ignored by the master, so it can be just an input.
So I think you should tie together the SS pin from each micro to a general-purpose IO line on the other. The master must assert the SS pin of the slave in order to be "heared".
Start with one micro as master and the other as slave. After transmission of a special character (or more), the roles are changed, so each micro must configure its SPI interface: the master to become a slave, the slave to become the master.
The new master must now assert the SS pin of the new slave.
To switch back, the present master must send the special character(s).
As you can see, this approach does not allow the slave to request a role swap.
So instead of characters, you can use IO lines tied fro one micro to the other, to let the slave request a role change. It costs precious IO lines, but it seems more flexible and does not place restrictions on the data sent.
