apolama
Member level 3
- Joined
- Nov 6, 2011
- Messages
- 56
- Helped
- 16
- Reputation
- 32
- Reaction score
- 16
- Trophy points
- 1,288
- Activity points
- 1,572
Is there any way to change input condition after checking the output value run-time in Hspice?
Actually I need to verify digital operation which needs long time as whole digital circuit needs to be designed first.
If there is any option in Hspice that it can check the output run-time and change the input signal, it can reduce time to check the digitally assisted analog block operation.
thanks in advance.
thanks in advance.
