change and edit symbol in allegro
aey
Member level 3
i have design and routed. if i want to change symbol(example dip16 into soic16) or edit pitch symbol in design. how to do?
you have to edit that into the schematic and than import the netlist again.
it have other way? if i have not schematic(brd file only). for mentor PADS it can right click and then edit footprint direct. and replace in eco mode easy. no change schematic.
No in allegro it is not like that you have to do it through schematic.
There is one way but I dont remember exactly it was through netlogic command i think try that option (you will need correct footprint and device files for that)
i see. thank you Anonymous_Ricky.
