Ceramic capacitor current ripple
ivenzar
Member level 2
Hello,
A 100V , x7r, 1210, 4.7uC capacitor is used. A rms current of 2 Amps flows over it. It's ESR its 0.006 Ohms.
It's maximum rated temperature is 125 ºC.
How can I know if the capacitor is able to work with that current. No Rth, nor maximum current, nor maximum are given in the datasheet.
Thanks
let´s assume the ESR is the only "power dissipating" part.
Then P_tot = I * I * ESR = 2A x 2A x 0.006 Ohms = 0.024W = 24mW.
--> Should be no problem for a 1210 sized device.
Is it too difficult to give us a link to the (complete) datasheet?
Maybe there references to other documents...Or there are additional informations at the manufacturer´s internet site.
Klaus
Same comment as Klaus.
Reputable capacitor manufacturers will provide ripple current limit values somewhere in the datasheet.
Sometimes the value is not found on the individual capacitor datasheet but as a global family specification.
Klaus
I have just founded the graph I need. RMSCurrent vs Temperature increase.
Thanks
