hrushchov
Hi there,
Need some help - it's about UMTS link budget power calculation and let's say we are using cdma with 512 codes.
How should one calculate the cdma coding gain on the downlink if, for example the BTS is using only one cdma code(from the whole 512) for the transmission? The gain is in regards to the signal power calculation, respectively the SNR.
It is clear that with more coding gain, less power is needed for the transmission, but what is the exact calculation or formula.
Thanks,
Thanks,
