ccs complier float issue with pic18f4620
raman00084
Full Member level 6
float32 a = 100/1000;
printf(%f,a)
the result is 0.00
if i change
float32 a =1000/1000
the result is 1.0
kindly help
regards
kalyan
The result is correct according to C type propagation rules and will be obtained with any C compiler. 100/1000 is calculated as integer division (result 0) and then converted to float.
You may want to write e.g.:
float32 a = 100.0/1000;
float32 a = 100/1000.0;
float32 a = float(100)/1000;
In any case, at least one of the numbers must be of the float type to cause a float division.
Yes, true indeed.
Typecast has higher priority than arithmetic operation, one pair of brackets can be omitted.
