ccs c writing to EEPROM example
mcjames
Newbie level 1
ext_eeprom_ready
Hi new here, was wondering if anyone could help me out:
I am using an example file by ccs for the driver. This is it:
#ifndef EEPROM_SDA
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#endif
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE    2048
//This is line 52
void init_ext_eeprom() {
   output_float(EEPROM_SCL);
   output_float(EEPROM_SDA);
BOOLEAN ext_eeprom_ready() {
   int1 ack;
   i2c_start();            // If the write command is acknowledged,
   ack = i2c_write(0xa0);  // then the device is ready.
   i2c_stop();
   return !ack;
void write_ext_eeprom(long int address, BYTE data) {
   while(!ext_eeprom_ready());
   i2c_start();
   i2c_write((0xa0|(BYTE)(address>>7))&0xfe);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
BYTE read_ext_eeprom(long int address) {
   BYTE data;
   i2c_start();
   i2c_write(address);
   i2c_start();
   i2c_write((0xa0|(BYTE)(address>>7))|1);
   data=i2c_read(0);
   i2c_stop();
   return(data);
Basically I have to change PIN_C4 and PIN_C3 to numbers mentioned in the header... once I've done that, I only get one error (as opposed to 4).
The error is
*** Error 128 "C:\Documents and Settings\James\My Documents\EngsclLP\WORK\PIC\Projects\EXTEEPROM\2416.C" Line 52(1,9): A #DEVICE required before this line
      1 Errors,  0 Warnings.
If anyone has any suggestions about how to fix this I would be grateful.
