hithesh123
Full Member level 6
- Joined
- Nov 21, 2009
- Messages
- 324
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- lax
- Activity points
- 3,548
I got a CC2510 USB Mini Dev kit.
I am trying to write a very simple(non-simpliciti) TX/RX program. One board for tx and other for rx.
Tx begins when a button is pressed. It transmits one packet with 5 bytes. Address checking is enabled on the receiver.
The tx board seems to be transmitting. I can see it transmit when I use smartRF studio in continuous RX mode. But can't see any RF when I check packet RX mode.
Can anyone help me with the tx code -
RF register config (using smartRF studio)
[COLOR="#0000FF"]while(1)
if (!P1_2) //button pressed(active low)
bcount+=1; //button press counter
RFST=0X03; //Strobe TX
RFD=rx1_addr; // Pkt ADDRESS
while(RFTXRXIF==1); //wait for clear interrupt
RFTXRXIF=0; // reset and write data
RFD=bcount;
//repeat with same or dummy data, bcoz pktlen is 05
RFD=bcount;
RFD=bcount;
RFD=bcount;
P1_0 =1;
delay(); //LED stays ON for a while
P1_0 =0;
//else enter low power mode with periodic wake up(1ms?)
}[/COLOR]
PKTLEN = 0x05; // packet length
PKTCTRL0 = 0x44; // packet automation control
CHANNR = 0x03; // channel number
FSCTRL1 = 0x0A; // frequency synthesizer control
FREQ2 = 0x5D; // frequency control word, high byte
FREQ1 = 0x93; // frequency control word, middle byte
FREQ0 = 0xB1; // frequency control word, low byte
MDMCFG4 = 0x86; // modem configuration
MDMCFG3 = 0x83; // modem configuration
MDMCFG2 = 0x03; // modem configuration
DEVIATN = 0x44; // modem deviation setting
MCSM0 = 0x14; // main radio control state machine configuration
FOCCFG = 0x16; // frequency offset compensation configuration
FSCAL1 = 0x00; // frequency synthesizer calibration
FSCAL0 = 0x11; // frequency synthesizer calibration
TEST1 = 0x31; // various test settings
TEST0 = 0x09; // various test settings
PA_TABLE0 = 0xFE; // pa power setting
IOCFG2 = 0x2E; // radio test signal configuration (p1_7)
IOCFG0 = 0x06; // radio test signal configuration (p1_5)
