[SOLVED] CC1100 read/write register problem?
Gigica
Newbie level 3
I am trying to read/write config registers in cc1100 as a first step to make RF communication but without success. Using ATmega8515 and code almost identical to this in next link but for AVR , not for PIC like in this example.
After reset I read the folowing config registers which are not default values for CC1100 , (1. problem) :
Addr. 0x00 : 0x00
Addr. 0x01 : 0x18
Addr. 0x02 : 0x3E
Addr. 0x03 : 0x06
Addr. 0x04 : 0x88
Addr. 0x05 : 0x00
Addr. 0x06 : 0xFE
Addr. 0x07 : 0x00
Addr. 0x08 : 0x00
Addr. 0x09 : 0x00
Addr. 0x0A : 0x00
Addr. 0x0B : 0x0E
Addr. 0x0C : 0x00
Addr. 0x0D : 0x1C
Addr. 0x0E : 0x80
Addr. 0x0F : 0xD0
Addr. 0x10 : 0x10
Addr. 0x11 : 0x00
Addr. 0x12 : 0x00
Addr. 0x13 : 0x00
Addr. 0x14 : 0xF0
Addr. 0x15 : 0x0C
Addr. 0x16 : 0x06
Addr. 0x17 : 0x20
Addr. 0x18 : 0x00
Addr. 0x19 : 0x68
Addr. 0x1A : 0x50
Addr. 0x1B : 0x02
Addr. 0x1C : 0x00
Addr. 0x1D : 0x00
Addr. 0x1E : 0x0C
Addr. 0x1F : 0x48
Addr. 0x20 : 0xF0
Addr. 0x21 : 0x10
Addr. 0x22 : 0x00
Addr. 0x23 : 0x00
Addr. 0x24 : 0x00
Addr. 0x25 : 0x00
Addr. 0x26 : 0x08
Addr. 0x27 : 0x00
Addr. 0x28 : 0x00
Addr. 0x29 : 0x20
Addr. 0x2A : 0x7E
Addr. 0x2B : 0x3E
Addr. 0x2C : 0x00
Addr. 0x2D : 0x20
Addr. 0x2E : 0x04
Second problem is that I cannot write to registers what I want and where I want . Some examples are when write to 0x03 register , value 0xBC , I read that value from config reg 0x01 etc. Some values seemed not to be written at all .
As from hardware Atmega8515 is connected to SPI lines of CC1100 via multiplexer and level translator that makes delay max 200ns that should not be problem .
The same results I got when spi avr module is used instead of spi-like software functions which are almost identical with those in link above .
Here are code snippets , most important :
[CODE]/////////////////////////////
#define SCK PORTB.7 //is connected to SCLK of CC1100
#define SI PINB.6  //is connected to SO of CC1100
#define SO PORTB.5 //is connected to SI of CC1100
#define CS PORTB.4  //is connected to CSn of CC1100
///SPI Based CC1100 Tranceiver module//////////////////////////////////////////
#define WRITE_SINGLE 0x00 //
#define WRITE_BURST 0x40 // || R/W- , B , AD5-AD0 ||
#define READ_SINGLE 0x80 //
#define READ_BURST 0xC0 //
unsigned char AD_SPI_write(unsigned char content)
unsigned char status=0x00;
unsigned char value=0x00,i;
SCK=0; //In IDLE clock should be 0
for(i=0;i<8;i++)
 value=(content & 0x80);
 if(value!=0x00) //checking each bits
 //SCK=0;
 SO=1;
 else
 //SCK=0;
 SO=0;
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
SCK=1; //clock from L to H
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
content=content<<1; //shifting for next bit
status=status<<1;
if(SI==1)
status=status|0x01;
else if(SI==0)
status=status&0xFE;
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
SCK=0;
SO=0;
return status;
unsigned char AD_SPI_read(void)
unsigned char i=0;
unsigned char content=0x00;
SCK=0;
for(i=0;i<8;i++)
content=content<<1;
SCK=1;
if(SI==1)
content=content|0x01;
else if(SI==0)
content=content&0xFE;
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
SCK=0;
#asm("nop");
#asm("nop");
#asm("nop");
#asm("nop");
SCK=0;
SO=0; //default position
//CS=1; //
return content;
////////////////////////END of SPI Functions///////////////////////////////////
unsigned char AD_CC1100_read_REG(unsigned char address)
unsigned char value;
address|=READ_SINGLE;
CS=1;
SCK=0; //jst to be sure
CS=0;
while(SI); //Wait for SI to become zero
AD_SPI_write(address);
delay_us(10); //A min 100ns delay bw each access
value=AD_SPI_read();
SCK=0;
//SI=1;
CS=1; //
return value;
void AD_CC1100_write_REG(unsigned char address, unsigned char value)
//unsigned char value;
CS=1;
SCK=0;
SCK=1;
SCK=0;
SCK=1;
SCK=0;
address|=WRITE_SINGLE;
CS=0;
while(SI);
delay_us(10);
AD_SPI_write(value);
SCK=0;
SO=0;
CS=1;
unsigned char AD_CC1100_POWERUP(void)
unsigned status=0xFF; // For debug to be deleated
CS=1; //default state
SCK=1;
SO=0;
CS=0;
delay_ms(5);
CS=1;
delay_ms(5);
CS=0;
CS=1;
status=AD_CC1100_command_STROBE(CC1100_SRES);
void main(void)
  Port B initialization
// Func7=Out Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
// State7=0 State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0xB0;
SCK=0;
SO=0;
delay_ms(100);
AD_CC1100_POWERUP();
while (1)
        //reading conf registers and send them to UART
        for(regCounter = 0x00; regCounter <= 0x2E; regCounter++)
                printf ("Addr. 0x%02X : ",regCounter);
                printf ("0x%02X\n\r",AD_CC1100_read_REG(regCounter));
         //write to conf register
         AD_CC1100_write_REG(tempReg,dataReg);
          printf("\n\r%2x written in %2x",dataReg,tempReg);
[/CODE]
Need help as soon as possible !
Gigica
Newbie level 3
The problem in my design was in hardware , ie. in multiplexer which on my developement system has some hanging pins . When I put some pull-ups , everything worked !
Another proof software that Mr. Joe333 has given , works !
