cavity backed antenna
akedar
Full Member level 5
can any body tell me how to design wide beamwidth (>120 deg) wide bandwidth (>1 GHz) in X-band with low cross-polarization cavity backed antenna asap
its urgent guys
ashutosh.kedar@gmail.com
edf
Full Member level 2
I once used a cavity backed slot (3/8 wavelength gnd spacing) that obtained an 88 deg beamwith and 10% bandwidth at 9GHz.
akedar
Full Member level 5
problem i am facing is of high cross-polarization can u suggest something
edf
Full Member level 2
You can start with these dimensions and experiment from there:
material: 0.254mm brass
slot dimensions: 16mm x0.8mm
feed tap from end of slot: approx 3mm
gnd spacing: approx 8.5mm
cavity extends approx 1/4 wavelength parallel to slot
akedar
Full Member level 5
Thanks for replying
I dont want slot antenna i want patch antenna supported by a cavity
can u send me something on that or some good papers u have:D
demian1977
Member level 1
If you are using a patch, why do you need a cavity? are there absorbing material in the cavity to reduce the bask scatter? If it's possible you can use a radom that polarize the radiated field or resonant dipole.
