Causes for UO faults in ATPG
ranger01
Full Member level 1
Santa Clara, CA
Hello DFT experts,
UO faults are faults which are not observed at the POs. What could be the possible causes for this category of faults ? When I run analyze_faults on a UO fault in mentor, it is detected successfully, however I do not understand why it wasn't put under DI/DS bucket.
you're PO always drive the same value?
or do you mean the PO is not connected to the internal scan chain and so the scan out does change?
I just defined UO faults in my question. The issue is with the tool. I had to re-target only the UO faults to detect them with higher abort.
