catching pulse below ground
yougarage
Member level 1
Member level 1
Hi, I have a variable reluctance sensor(a pick up) monitoring a half moon wheel.One wire of the sensor is grounded. It's output is a positive pulse when the pickup meet the full edge of the wheel, and a negative pulse when it meets the other edge. I need to pick these signals to feed a mcu, I know how to condition the positive one, but how can I pick the negative one? Ground is shared between the mcu and one side of the pickup.I tought of a pnp transistor, do you suggest anything better?
It requires a small coupling capacitor with equal pull-up/down resistors like 10k and appropriate Schmitt trigger. This biases the signal to V+/2
If this is new to you, here are some details.
Thanks for your replies
both solutions look interesting, however the first avoid a current load to the sensor, right?
Correct. My method has a few uA travelling down through the sensor. If your sensor cannot sink current then you need to feed its signal to a device which is voltage controlled.
