Cascode Power Amplifier
jayce3390
Full Member level 6
Full Member level 6
Hey Users,
It seems that the cascode PA topology allows to double the nominal drain supply voltage that a single transistor can handle.
Does anyone of you know ?
Thanks
  • cascode4.pdf
If you presume that the safe Vdd level will be limited by maximum Vdg rather than Vds, then a cascode amplifier allows higher Vdd values, because the gate doesn't swing against drain node. That's not the strong effect discussed in the otherwise quoted "self-balancing cascode" papers, but still valuable.
But I don't see that the Vdd factor two stated in the text is supported by the comparative tables.
