Capacitive Power Supply
me_guitarist
Full Member level 6
Malaysia
capacitive power supply
Hi guys,
I used this capacitive power supply to run some LED from 240VAC.
R1=2W10R Metal Oxide Resistor
C1=1.5uf 450VAC(x2 Type)
C2=220uf 35V
D1=24V
D2=1N4007
The output around 35VDC. Everything running smoothly. But when I switched off the main 240VAC, there is still around 250VDC inside C1 & I get electric short. How do I discharge C1?
Pls help. Thanks in advance.[/img]
FvM
Super Moderator
Staff member
Bochum, Germany
capacitive supply
Apart from the problem of of providing a safe protection against accidental contact for your circuit, I think you shouldn't operate it open circuit (at 35 V output), cause this overloads D1. As another remark you could double the output current efficiency by using a full wave rectifier.
Finally C1 can be discharged by a high ohmic resistor, e. g. 1 MOhm.
Reactions: jayp
    jayp
me_guitarist
Full Member level 6
Malaysia
working of capacitive power supply
Hi FvM,
Thanks for yr input.
U mean put a 1/4W 1M resistor parallel to C1?
yanzixuan
Member level 3
capacitive power supply design
me_guitarist said:
Hi FvM,
1/4w 400k~800k resistor parallel to C1;
or
1/2w 200k~400k resistor parallel to C1;
me_guitarist
Full Member level 6
Malaysia
capacitive power
yanzixuan said:
me_guitarist said:
Hi FvM,
or
I tried 1/4W 1M is ok.
Thanks yanzixuan & FvM.
me_guitarist
Full Member level 6
Malaysia
400k resistor
Why is that D1 overload? As it should output 24VDC right?
This circuit is proper isolated.
FvM
Super Moderator
Staff member
Bochum, Germany
capacitive power supplies
With no load connected, D1 is dissipating about 1.2W, if not using a power Z-diode, this means thermal overload.
yanzixuan
Member level 3
full wave capacitive power supply
Rc=1/(2*pi*f*c)=1/(2*3.14*50*3*10^-6)~~1.06k;
R1=10.
Iin~~240/(Rc+R1)=220ma;
Pd1=((Iin*VD*T/2)+(Iin*Vth*T/2))/T=Iin*(Vd+Vth)/2=0.22*(24+0.7)/2=2.717w
max0412
Full Member level 5
capacative power supply
Definitely not,there is no isolation!
These regulators are meant to be in an enclosure with no possible way a user can come into contact with it. As long as this is the case they have there uses .
me_guitarist
Full Member level 6
Malaysia
capactive power supply
These regulators are meant to be in an enclosure with no possible way a user can come into contact with it. As long as this is the case they have there uses .[/quote
The circuit was inside an enclosure. Its away from user touching.
I ran this circuit for a week & its ok until now.
FvM
Super Moderator
Staff member
Bochum, Germany
calculation of capacitive power supply
Isn't correct. You apparently understood x2-type as two caps in parallel. But X2 is a type specification of AC filter caps. So C is 1.5uF and the current is only half. Also the Z-diode voltage drop has to be considered in current calculation, so I think, an estimation of 1.2 W(@230 V) is rather exact.
me_guitarist
Full Member level 6
Malaysia
rc=1/2*pi*f
If I put 2W for ZD1 will it sufficient?
FvM
Super Moderator
Staff member
Bochum, Germany
full-wave rectifier current calculation
Yes, also the high Z-diode power dissipation is only occurring in no load case. It has to be considered only, of the load can be disconnected somehow.
me_guitarist
Full Member level 6
Malaysia
capasitive psu
Can I put C1 before R1? To suit my application.
