Capacitance effect due to more vias and metal straps.
reddvoid
Junior Member level 3
L1 output pin  uses M1 for output pin + 2M0 vias to M0 straps
L2 output pin  uses M2 for output pin + 6 M1Vias to 6 M1 straps + 12 M0 vias to M0 straps  lower cap than L1
L1 input pin  uses M0 layer
L2 input pinuses M1 layer 1 M0 via to M0  lower cap than L1
I have these two layouts, both are of same size (INVERTER LAYOUTS)
though L2 is using more straps and vias in addition to what L1 is using, I am seeing lower caps on input and output nets of L2, when I do the extraction in virtuoso.
I expected higher caps on input and output nets in L1
am I missing something? , Higher layers have lower cap, but L2 is using higher layers plus the layers used by L1 , so clearly I was expecting higher caps in L2
am I missing something or its due to some messup in extraction ?
Thank you.
reddvoid
L1 output pin --> uses M1 for output pin + 2M0 vias to M0 straps
L2 output pin --> uses M2 for output pin + 6 M1Vias to 6 M1 straps + 12 M0 vias to M0 straps --> lower cap than L1
L1 input pin --> uses M0 layer
L2 input pin-->uses M1 layer 1 M0 via to M0 --> lower cap than L1
Thank you.
Updated question
ranaya
Full Member level 1
Kelaniya
Are you referring to the total input/output caps seen through these pins ? What are the NMOS/PMOS sizes used in these two layouts ? In which technology ?
Anuradha
