o_0
Member level 3
I'm trying to calculate the tip deflection of a horizontal cantilever beam for various materials and lengths, assuming the only force is gravity.
According to the lecture notes, the formula is this:
\[y^{tip}_{gravity} = \frac{3 \rho (L^4)}{2 E t^2}g\]
(Just in case the picture doesn't show up, it's this: y^{tip}_{gravity} = \frac{3 \rho (L^4)}{2 E t^2}g)
Using matlab I get the following results:
However, the results for 100 microns don't seem to make sense, since the units would be meters. My code is below, I also got the values of the constants from the lecture notes. The only values I converted were the densities, from g/cm3 to g/m3 because everything else was given in terms of meters. Any assistance would be appreciated, thanks in advance.
Also, for low pressure damping it wasn't specified what pressure to put in the formula, can I just put in atmospheric? Or 1 torr?
L = 10 microns L = 100 microns
SiO2 0.0050 50.3
Si 0.0018 17.8
Al 0.0057 56.7
% dimensions in meters
L1 = 10e-6;
L2 = 100e-6;
W = 5e-6;
T = 1e-6;
g = 9.8; % m/s^2
E_SiO2 = 73;
E_Si = 190;
E_Al = 70;
% Young's modulus N/m^2
% density (g/m^3)
p_SiO2 = 2.5*100*100*100;
p_Si = 2.3*100*100*100;
p_Al = 2.7*100*100*100;
% Tip deflection, only force is gravity
y_tip_SiO2_L1 = ((3*p_SiO2*(L1^4))/(2*E_SiO2*(T^2)))*g
y_tip_SiO2_L2 = ((3*p_SiO2*(L2^4))/(2*E_SiO2*(T^2)))*g
y_tip_Si_L1 = ((3*p_Si*(L1^4))/(2*E_Si*(T^2)))*g
y_tip_Si_L2 = ((3*p_Si*(L2^4))/(2*E_Si*(T^2)))*g
y_tip_Al_L1 = ((3*p_Al*(L1^4))/(2*E_Al*(T^2)))*g
y_tip_Al_L2 = ((3*p_Al*(L2^4))/(2*E_Al*(T^2)))*g
