[SOLVED] Can't send SMS using AT commands
Isuru Senarath
Member level 2
hi all,
I am trying to Send SMS using AT commands when I press the keypad button. I can send SMS using hyper-terminal (AT+CMGS="TEL NO"
MESSAGE
CTRLZ)
I think something wrong with my C program. Please guide me to send sms using C programming.
if(rowLoc == 3 && colLoc == 0x0D)                           // keypad 0
                                        SMSString( "\r");
                                        Delay(50);
                                        SMSString( "AT+CMGS=\"0718021336\"\r");//my mob number here
                                        Delay(50);
                                        SMSString("7.10PM");
                                        Delay(50);
                                        SMSString("CTRLZ");
					Delay(50);
					SMSString( "\r");
                                        Delay(50);
										lcdcmd(0x01);  //clear screen
                                        lcdcmd(0x80);        //Row 1 and First Column
                                        lcd_data_string("Info. Sent: 7.10PM ");
                                        Delay(10);
                                        lcdcmd(0x0C0);
                                        lcd_data_string("ACHIVE Y/N?  ");
                                        Delay(10);
try this i think it will work
                                        SMSString(0x0D);
                                        SMSString( "AT+CMGF=1");
                                        SMSString(0x0D);
                                        Delay(50);
                                        SMSString( "AT+CMGS="0718021336");//my mob number here
                                        SMSString(0x0D);
                                        Delay(50);
                                        Delay(50);
                                        SMSString(0x1A);
					Delay(50);
                                        SMSString(0x0D);
                                        Delay(50);
                                        Delay(10);
                                        lcdcmd(0x0C0);
                                        Delay(10);
send the smsstring code
what is "CTRLZ" meand string or Ctrl Z
CTRLZ is sms string which I used to put Ctrl+Z (to send) sms
i don't know you can use CTRLZ for Ctrl+Z try using 0x1A followed by 0x0d 0x0a
instead of modem connect to pc com port and check using hyper terminal all message are going to modem is correct
Can we use 0x1A as
SMSString(0x1A);
I have define the SMSString as
void SMSString(char*text) ;
no you cant use void SMSString(char*text) for character, i thing you can use you can use putc(0x1d);
which compiler you are using
---------- Post added at 18:37 ---------- Previous post was at 18:36 ----------
post your void SMSString(char*text) ; code
Im using Keil uVision3. Can You please tel me how to define this 0x1A
in keil i thing you can use putchar function like putchar(0x1a);
you have to include stdio.h header file
void SMSString(unsigned char* text) //function to send SMS using GSM modem
        while (*text)
                SerTX(*text++);
SerTX() ? is it your function on Keil
This is my full program. I use a keypad to enter details (sms body) and send it to another unit which will display received sms.
#include <REGX51.H>
#include<string.h>
#define COL P2
#define ROW P0
#define CTRLZ 26
sfr LcdData = 0x90;                                                        //LCD Data Pins
sbit RS =  P2^5;
sbit RW =  P2^6;
sbit EN =  P2^7;
//Function Prototype Declaration
void lcd_data_string(unsigned char *str);
void lcdcmd(unsigned char value);
void lcddata(unsigned char value);
void Delay(unsigned int itime);
void SerTX(unsigned char);
unsigned char msg[] = "Enter Info:-";
unsigned char CtrlZ=0x1A;
unsigned char keypad[4][4] =        {'1','2','3','A',
        '4','4','6','B',
        '7','8','9','C',
        'Y','0','N',':'};
void main()
        unsigned char colLoc,rowLoc;
        unsigned int len,i;
        LcdData = 0x00;                 //Port-1 as Output Port
        TMOD = 0x20;        //For Baud Rate Generation
        TH1 = -3;                //Baud Rate of 9600bps
        SCON = 0x50;
        TR1 = 1;                //Start Timer-1
        //LCD Initialization Commands
        SMSString("AT\r"); // AT commands to initialize gsm modem
        Delay(50);
        SMSString( "ATe0\r"); // turn off echo
        Delay(50);
        SMSString( "AT+CMGF=1\r"); // turn off echo
        Delay(50);
        SMSString( "AT&W\r"); // save settings
        Delay(50);
        lcdcmd(0x38);        //Initialize LCD Commands
        Delay(1);
        lcdcmd(0x0E);        //Display on Cursor Blinking
        Delay(1);
        lcdcmd(0x01);        //Clear LCD
        Delay(1);
        //lcd_data_string("Bus Route Info.");
        //Delay(10);
        //lcdcmd(0x0C0);
        //lcd_data_string("System Project");
        //Delay(10);
        Delay(1);
        len = strlen(msg);
        for(i=0;i<len;i++)
                lcddata(msg[i]);
                Delay(1);
        lcdcmd(0x0C0);                                                //Move to Second Line of the LCD
        COL =  0x0FF;                                                //Make Port-2 as Input Port
        while(1)        //Infinite Loop
                do
                        ROW = 0x00;                                                //Groud all Row's
                        colLoc = COL;                                        //Read all the Columns
                        colLoc = colLoc & 0x0F;                        //Mask the Unused Bits.
                }while(colLoc != 0x0F);                         //Check until all the Keys are released
                do
                        do
                                Delay(2);                                        //20msec delay
                        }while(colLoc == 0x0F);                         //Keep Checking for Key-press
                        //It may be possible that this key-press may be due to some noise-spikes in the circuit
                        //thats why we will check once again whether the same key is pressed or not.
                        //If not the whole loop will be executed once again
                        Delay(2);
                        colLoc = COL;                                        //read all columns
                }while(colLoc == 0x0F);                                //Wait for the Key-Press
                while(1)
                        ROW = 0x0FE;                                        //Ground First Row
                        colLoc = COL;
                        if(colLoc != 0x0F)                                //1111 Column Detected
                                rowLoc = 0;                                        //1st Row Selected
                                break;
                        ROW = 0x0FD;                                        //Ground Second Row
                        colLoc = COL;
                        if(colLoc != 0x0F)                                //Column Detected
                                rowLoc = 1;                                        //2nd Row Selected
                                break;
                        ROW = 0x0FB;                                        //Ground Third Row
                        colLoc = COL;
                                rowLoc = 2;                                        //3rd Row Selected
                                break;
                        ROW = 0x0F7;                                        //Ground Fourth Row
                        colLoc = COL;
                        if(colLoc!= 0x0F)
                                rowLoc = 3;                                        //4th Row Selected
                                break;
                if(colLoc == 0x0E)                                  //1110 This means that First column is Selected
                        SerTX(keypad[rowLoc][0]);
                else if(colLoc == 0x0D)                        // 1101
                        SerTX(keypad[rowLoc][1]);
                else if(colLoc == 0x0B)                         // 1011
                        SerTX(keypad[rowLoc][2]);
                else if(colLoc == 0x07)                          // 0111
                        SerTX(keypad[rowLoc][3]);
                //lcdcmd(0xC0);        //Second Row
                        //Check Columns and send the Data to the LCD Screen:-
                                lcddata(keypad[rowLoc][0]);
                                lcddata(keypad[rowLoc][1]);
                                lcddata(keypad[rowLoc][2]);
                                lcddata(keypad[rowLoc][3]);
                                        SMSString( "\r");
                                        Delay(50);
                                        Delay(50);
                                        Delay(50);
                                        SMSString("CTRLZ");
										Delay(50);
										SMSString( "\r");
                                        Delay(50);
                                        Delay(10);
                                        lcdcmd(0x0C0);
                                        Delay(10);
        LcdData = value;
        RS = 0;
        RW = 0;
        EN = 1;
        Delay(1);
        EN = 0;
        LcdData = value;
        RS = 1;
        RW = 0;
        EN = 1;
        Delay(1);
        EN = 0;
        unsigned int i,j;
        for(i=0;i<1275;i++)
        for(j=0;j<itime;j++);
void SerTX(unsigned char x)
        SBUF = x;
        while(TI == 0);
        TI = 0;
void lcd_data(unsigned char item)                // Function to send one byte data to LCD
        LcdData = item;
        RS= 1;
        RW=0;
        EN=1;
        Delay(1);
        EN=0;
        return;
void lcd_data_string(unsigned char *str)        // Function to send string to LCD
        int i=0;
        while(str[i]!='\0')
                lcd_data(str[i]);
                i++;
                Delay(10);
        return;
        while (*text)
                SerTX(*text++);
change SMSString("CTRLZ"); to putchar(0x1A);
and add #include<stdio.h>
and check
Program will run upto putchar(0x1A); and stop there. See attachment :
                                        Delay(50);
                                        Delay(50);
                                        putchar(0x1A);
										Delay(50);[ATTACH=CONFIG]74712._xfImport[/ATTACH]
Its working, Thanks a lot. :smile: Highly appreciate your help. Thanks again.
