Jun 19, 2007 #1 I ianalog Junior Member level 1 Joined Dec 4, 2006 Messages 15 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,372 hello, everyone. I designing a layout based on 0.18u, the PP tool is SOC encounter. when i open the GDS file with virtuoso, I don't see the ACTIVE, NWELL, NSD and PSD. would you tell me is it correct ? thank you !
Jun 19, 2007 #2 B batistuta Member level 5 Joined Jun 14, 2007 Messages 94 Helped 4 Reputation 8 Reaction score 0 Trophy points 1,288 Activity points 1,845 Re: 018u layout question you make sure you have copy the display.grf to your current path??
Jun 19, 2007 #3 J jfyan Full Member level 2 Joined May 3, 2006 Messages 145 Helped 26 Reputation 52 Reaction score 4 Trophy points 1,298 Location shanghai,china Activity points 2,064 Re: 018u layout question batistuta said: you make sure you have copy the display.grf to your current path?? Click to expand... it may be display.drf
Jun 19, 2007 #4 L layout_designer Member level 5 Joined Jan 9, 2006 Messages 87 Helped 14 Reputation 28 Reaction score 6 Trophy points 1,288 Activity points 1,869 Re: 018u layout question Your setup may be not loaeded properly
Jun 20, 2007 #5 I ianalog Junior Member level 1 Joined Dec 4, 2006 Messages 15 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,372 018u layout question I have copy the display file, dont know why? Added after 6 minutes: down load sample file can see all layer, but the std_lib file can not be seen all layer. why?
Jun 20, 2007 #6 P psmon Full Member level 3 Joined Jun 4, 2007 Messages 163 Helped 20 Reputation 40 Reaction score 4 Trophy points 1,298 Activity points 1,907 018u layout question If you have the display file, you must also enable the layers to see them !
Jun 21, 2007 #7 S sxunxs Junior Member level 1 Joined May 18, 2007 Messages 19 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,283 Location Philippines Activity points 1,404 Re: 018u layout question be sure that the library is properly attached to tech file...
Jun 21, 2007 #8 D dongqing Junior Member level 3 Joined Jun 21, 2007 Messages 31 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,459 Re: 018u layout question Hi guy: May something wrong whan you load it. You can log-out, than do it again following the right way. Sometimes it can be solved. best regards dongqing
