/* Files to Include */
#ifdef __XC32
#include <xc.h> /* Defines special funciton registers, CP0 regs */
#endif
#include <plib.h> /* Include to use PIC32 peripheral libraries */
#include <stdint.h> /* For uint32_t definition */
#include <stdbool.h> /* For true/false definition */
#include "system.h" /* System funct/params, like osc/periph config */
#include "user.h" /* User funct/params, such as InitApp */
/* Global Variable Declaration */
/* i.e. uint32_t <variable_name>; */
/* Main Program */
/*Software Driver
SST26VF016B 16 Mbit(2M x 8) Serial Quad I/O (SQI) Flash Memory
Apr 8, 2015, Rev. 1.0
ABOUT THE SOFTWARE
This application note provides software driver examples for SST26VF016B,
Serial Flash. Extensive comments are included in each routine to describe
the function of each routine. The interface coding uses polling method
rather than the SPI protocol to interface with these serial devices. The
functions are differentiated below in terms of the communication protocols
(uses Mode 0) and specific device operation instructions.
ABOUT THE SST26VF016B
Companion product datasheets for the SST26VF016B should be reviewed in
conjunction with this application note for a complete understanding
of the device.
Device Communication Protocol(pinout related) functions:
Functions Function
init Initializes clock to set up mode 0.
Send_Byte Sends one byte using SI pin to send and
shift out 1-bit per clock rising edge
Get_Byte Receives one byte using SO pin to receive and shift
in 1-bit per clock falling edge
SendSQI_Byte Sends one byte using SI pin, SO pin, SIO2 pin and SIO3 pin to send and
shift out 4-bit per clock rising edge
GetSQI_Byte Receives one byte using SI pin, SO pin, SIO2 pin and SIO3 pin to receive and shift
in 4-bit per clock falling edge
Note: The pin names of the SST26VF032 are used in this application note. The associated test code
will not compile unless these pinouts (SCK, SI, SO, SIO2, SIO3, CE) are pre-defined on your
software which should reflect your hardware interfaced.
Device Operation Instruction functions:
Functions Function
NoOp No Operation
RSTEN Enables acceptance of the RST (Reset) operation command
RST Resets the device in to normal operating Ready mode
EQIO Enables Quad I/O operation
RSTQIO Resets the device to 1-bit SPI protocol operation
Read Reads one byte from the serial flash and returns byte(max of 33 MHz CLK frequency)
Read_Cont Reads multiple bytes(max of 33 MHz CLK frequency)
HighSpeed_Read Reads one byte from the serial flash and returns byte(max of 80 MHz CLK frequency)
HighSpeed_Read_Cont Reads multiple bytes(max of 80 MHz CLK frequency)
SQOR SPI Quad Output Read
SQIOR SPI Quad I/O Read
SDOR SPI Dual output read
SDIOR SPI Dual I/O Read
Set_Burst Specifies the number of bytes (8,16,32 or 64 bytes) to output during a Read Burst command
Read_Burst Reads multiple bytes as specified by Set_Burst
RBSPI SPI Read Burst with Wrap
Jedec_ID_Read Reads the Jedec ID using SPI protocol
Quad J-ID Reads the Jedec ID using Quad I/O protocal
SFDP Serial Flash Discoverable Parameter
Sector_Erase Erases one sector (4 KB) of the serial flash
Block_Erase Erases 32 KByte block memory of the serial flash
Chip_Erase Erases entire serial flash
Page_Program Programs 1 to 256 Data Bytes
SPI Quad PP SPI Quad Page Program
Write Suspend Suspends Program/Erase operation
Write Resume Resumes Program/Erase operation
nVWLDR non-Volatile Write Lock-Down Register
ULBPR Global Block Protection Unlock
Read SID Read Security ID
Prog SID Program User Security ID area
Lock SID Lockout Security ID Programming
RDSR Reads the status register of the serial flash
WRSR Write to the status register and configuration register
RDCR Read Configuration Register
WREN Write enables the serial flash
WRDI Write disables the serial flash
RBPR Read Block Protection Register
WBPR Write Block Protection Register
LBPR Lock Block Protection Register
Wait_Busy Polls status register and waits until busy bit is low
//"C" LANGUAGE DRIVERS
/* Copyright Microchip(SST), 1994-2015 */
/* Example "C" language Driver of SST26VF016B Serial Flash */
/* Hardik Patel, Microchip */
/* Revision 1.0, Apr 8, 2015 */
// include files
#include <xc.h>
#include <proc/p32mx230f064d.h>
// defines
// configuration bits
#pragma config UPLLEN = ON // USB PLL Enabled
#pragma config FPLLIDIV = DIV_2 // PLL Input Divider
#pragma config FPLLMUL = MUL_20 // PLL Multiplier
#pragma config UPLLIDIV = DIV_2 // USB PLL Input Divider
#pragma config FPLLODIV = DIV_4 // PLL Output Divider
#pragma config FPBDIV = DIV_4 // Peripheral Clock divisor so clk is 5MHZ
#pragma config FWDTEN = OFF // Watchdog Timer
#pragma config WDTPS = PS1 // Watchdog Timer Postscale
#pragma config FCKSM = CSDCMD // Clock Switching & Fail Safe Clock Monitor
#pragma config OSCIOFNC = OFF // CLKO Enable
#pragma config POSCMOD = HS // Primary Oscillator
#pragma config IESO = OFF // Internal/External Switch-over
#pragma config FSOSCEN = OFF // Secondary Oscillator Enable (KLO was off)
#pragma config FNOSC = PRIPLL // Oscillator Selection
#pragma config CP = OFF // Code Protect
#pragma config BWP = OFF // Boot Flash Write Protect
#pragma config PWP = OFF // Program Flash Write Protect
//#pragma config ICESEL = ICS_PGx1 // ICE/ICD Comm Channel Select
#pragma config DEBUG = OFF
/* Pin Function Prototypes */
void Portassign();
void SetSIO0_Output();
void SetSIO0_Input();
void SetSIO1_Output();
void SetSIO1_Input();
void SetSIO2_Output();
void SetSIO2_Input();
void SetSIO3_Output();
void SetSIO3_Input();
void SIO0_Low();
void SIO1_Low();
void SIO2_Low();
void SIO3_Low();
void SIO0_High();
void SIO1_High();
void SIO2_High();
void SIO3_High();
void SCK_High();
void SCK_Low();
void CE_High();
void CE_Low();
void Reset_Hold_Low();
void Reset_Hold_High();
void WP_Low();
void WP_High();
void DisplayLED(char Led_Stat);
/* Function Prototypes */
void init();
void NoOp();
void Send_Byte(unsigned char out);
void Send_Double_Byte(unsigned char out);
void SendSQI_Byte(unsigned char out);
unsigned char Get_Byte();
unsigned char Get_Double_Byte();
unsigned char GetSQI_Nibble();
unsigned char GetSQI_Byte();
void ResetEn();
void Reset();
void En_QIO();
void Reset_QIO();
unsigned char Read(unsigned long Dst);
void Read_Cont(unsigned long Dst, unsigned long no_bytes);
unsigned char HighSpeed_Read(unsigned long Dst);
void HighSpeed_Read_Cont(unsigned long Dst, unsigned long no_bytes);
void Set_Burst(unsigned char byte);
void Read_Burst(unsigned long Dst, unsigned char burstlength);
void Read_PI(unsigned char Dst, unsigned char datalength);
void Read_Index(unsigned long Dst, unsigned char datalength);
void Read_BlockIndex(unsigned char Dst, unsigned char datalength);
void Jedec_ID_Read();
void QuadJ_ID_Read();
void SPI_Quad_IO_InMode_Read_Cont(unsigned long Dst, unsigned long no_bytes);
unsigned char SPI_Quad_IO_InMode_Read(unsigned long Dst);
unsigned char SPI_Quad_IO_NotInMode_Read(unsigned long Dst);
void SPI_Quad_IO_NotInMode_Read_Cont(unsigned long Dst, unsigned long no_bytes);
unsigned char SPI_Double_IO_InMode_Read(unsigned long Dst);
unsigned char SPI_Double_IO_NotInMode_Read(unsigned long Dst);
void SPI_Double_IO_NotInMode_Read_Cont(unsigned long Dst, unsigned long no_bytes);
void SPI_Double_IO_InMode_Read_Cont(unsigned long Dst, unsigned long no_bytes);
void HighSpeed_NotInMode_Read_Cont(unsigned long Dst, unsigned long no_bytes);
void HighSpeed_InMode_Read_Cont(unsigned long Dst, unsigned long no_bytes);
unsigned char HighSpeed_InMode_Read(unsigned long Dst);
unsigned char HighSpeed_NotInMode_Read(unsigned long Dst);
void Sector_Erase(unsigned long Dst);
void Block_Erase(unsigned long Dst);
void Chip_Erase();
void Page_Program(unsigned long Dst);
void Write_Suspend();
void Write_Resume();
void ReadSID(unsigned char *security_ID, unsigned long Dst, unsigned long security_length);
void ProgSID(unsigned char *security_ID, unsigned long Dst, unsigned long security_length);
void LockSID();
unsigned char Read_Status_Register();
void WREN();
void WRDI();
void ReadBlockProtection();
void WriteBlockProtection();
void LockBlockProtection();
void SPI_Global_Block_Protection_Unlock();
void Global_Block_Protection_Unlock();
void Wait_Busy();
void Wait_Busy_special();
void SPI_Wait_Busy_special();
unsigned char SPI_SFDP_Read(unsigned long Dst);
unsigned int data_256[256],data2[256]; /* global array to store read data */
unsigned int block_protection_6[6]; /* global array to store block_protection data */
unsigned char Manufacturer_Id, Device_Type, Device_Id; /* global array to store Manufacturer and Device id information */
char Sw;
char buffer[15];
unsigned long deviceaddress;
/* PROCEDURE: Port Assign */
/* This procedure sets the Ports for SPI communicaiton and LED Display. */
/* LATA is for LED display. LATF is for SPI communication. */
//void Portassign()
// LATA = 0x0000; // set LAT A output latches low
// TRISA = 0x0000; // set LAT A pins to be outputs
// LATF = 0x0000;
// TRISF =0x0000; //Set everything to be output.
TRISAbits.TRISA8=1; /////
Nop();Nop();
Nop();Nop();
/* PROCEDURE: SetSIO0_Output, SetSIO0_Input */
/* This procedure sets the Ports for SQI communicaiton */
TRISAbits.TRISA8=0;
Nop();Nop();
Nop();Nop();
TRISAbits.TRISA4=0;
Nop();Nop();
Nop();Nop();
TRISAbits.TRISA4=1;
Nop();Nop();
Nop();Nop();
//TRISF = TRISF & ~(0x0001);
//TRISF = TRISF | (0x0001);
//TRISF = TRISF & ~(0x0002);
//TRISF = TRISF | (0x0002);
/* PROCEDURE: Display LED */
/* This procedure is used to diplay a byte on 8 LEDs which are */
/* connected to LATA */
//void DisplayLED(char Led_Stat)
// LATA=Led_Stat;
/* PROCEDURE: SCK_High */
/* This procedure set SCK = High. */
void SCK_High()
ANSELBbits.ANSB15=0;
PORTBbits.RB15=1; /* set SCK high */
Nop();Nop();
Nop();Nop();
/* PROCEDURE: SCK_Low */
/* This procedure drives the SCK of the device to low. */
void SCK_Low()
PORTBbits.RB15=0; /* clear SCK low */
Nop();Nop();
Nop();Nop();
/* PROCEDURE: CE_High */
/* This procedure set CE = High. */
void CE_High()
TRISCbits.TRISC4=0;
Nop();Nop();
Nop();Nop();
PORTCbits.RC4=1; /* set CE high */
Nop();Nop();
Nop();Nop();
/* PROCEDURE: CE_Low */
/* This procedure drives the CE of the device to low. */
void CE_Low()
PORTCbits.RC4=0; /* clear CE low */
Nop();Nop();
Nop();Nop();
/* PROCEDURE: Reset_Hold_Low() */
/* This procedure clears the Reset_Hold pin to low. */
//LATF = LATF & ~(0x0002); /* clear Hold pin */
/* PROCEDURE: Reset_Hold_High() */
/* This procedure sets the Reset_Hold pin to high. */
//LATF = LATF | (0x02); /* set Hold pin */
/* PROCEDURE: WP_Low() */
/* This procedure clears the WP pin to low. */
void WP_Low()
//LATF = LATF & ~(0x0001); /* clear WP pin */
/* PROCEDURE: WP_High() */
/* This procedure sets the WP pin to high. */
void WP_High()
//LATF = LATF | (0x01); /* set WP pin */
/* PROCEDURE: SIO0_High */
/* This procedure set SIO0 = High. */
void SIO0_High()
PORTAbits.RA8=1; /* set SIO0 high */
Nop();Nop();
Nop();Nop();
/* PROCEDURE: SIO0_Low */
/* This procedure drives the SIO0 of the device to low. */
void SIO0_Low()
PORTAbits.RA8=0; /* clear SIO0 low */
Nop();Nop();
Nop();Nop();
/* PROCEDURE: SIO1_High */
/* This procedure set SIO1 = High. */
void SIO1_High()
PORTAbits.RA4=1; /* set SIO1 high */
Nop();Nop();
Nop();Nop();
/* PROCEDURE: SIO1_Low */
/* This procedure drives the SIO1 of the device to low. */
void SIO1_Low()
PORTAbits.RA4=0; /* clear SIO1 low */
Nop();Nop();
Nop();Nop();
Nop();Nop();
/* PROCEDURE: SIO2_High */
/* This procedure set SIO2 = High. */
void SIO2_High()
// LATF = LATF | (0x001); /* set SIO2 high */
/* PROCEDURE: SIO2_Low */
/* This procedure drives the SIO2 of the device to low. */
void SIO2_Low()
//LATF = LATF & ~(0x0001); /* clear SIO2 low */
/* PROCEDURE: SIO3_High */
/* This procedure set SIO3 = High. */
void SIO3_High()
//LATF = LATF | (0x002); /* set SIO3 high */
/* PROCEDURE: SIO3_Low */
/* This procedure drives the SIO3 of the device to low. */
void SIO3_Low()
//LATF = LATF & ~(0x0002); /* clear SIO3 low */
/* PROCEDURE: init */
/* This procedure initializes the SCK to low. Must be called prior to */
/* setting up mode 0. */
void init()
TRISBbits.TRISB15=0;
SCK_Low(); /* set clock to low initial state */
/* PROCEDURE: Send_Byte */
/* This procedure outputs a byte shifting out 1-bit per clock rising */
/* edge on the the SI pin (SIO0 pin) LSB 1st. */
unsigned char i = 0;
SetSIO0_Output();
for (i = 0; i < 8; i++)
if ((out & 0x80) == 0x80) /* check if MSB is high */
SIO0_High();
else
SIO0_Low(); /* if not, set to low */
SCK_High(); /* toggle clock high */
out = (out << 1); /* shift 1 place for next bit */
SCK_Low(); /* toggle clock low */
/* PROCEDURE: Send_Double_Byte */
/* This procedure outputs a byte shifting out 2-bit per clock rising */
/* edge on the the SI pin and SO pin (SIO0,SIO1) MSB 1st. */
SetSIO0_Output();
SetSIO1_Output();
if ((out & 0x80) ==0x80)
{SIO1_High();}
else
{SIO1_Low();}
if ((out & 0x40) ==0x40)
{SIO0_High();}
else
{SIO0_Low();}
if ((out & 0x20) ==0x20)
{SIO1_High();}
else
{SIO1_Low();}
if ((out & 0x10) ==0x10)
{SIO0_High();}
else
{SIO0_Low();}
if ((out & 0x08) ==0x08)
{SIO1_High();}
else
{SIO1_Low();}
if ((out & 0x04) ==0x04)
{SIO0_High();}
else
{SIO0_Low();}
if ((out & 0x02) ==0x02)
{SIO1_High();}
else
{SIO1_Low();}
if ((out & 0x01) ==0x01)
{SIO0_High();}
else
{SIO0_Low();}
SIO0_High(); //Set them as Inputs
SIO1_High();
/* PROCEDURE: SendSQI_Nibble */
/* edge on the the SI0, SIO1, SIO2, SIO2 pin (LSB 1st). */
SetSIO0_Output();
SetSIO1_Output();
SetSIO2_Output();
SetSIO3_Output();
{SIO3_High();}
else
{SIO3_Low();}
{SIO2_High();}
else
{SIO2_Low();}
{SIO1_High();}
else
{SIO1_Low();}
{SIO0_High();}
else
{SIO0_Low();}
if ((out & 0x08) == 0x08) /* check if MSB is high */
{SIO3_High();}
else
{SIO3_Low();}
{SIO2_High();}
else
{SIO2_Low();}
{SIO1_High();}
else
{SIO1_Low();}
{SIO0_High();}
else
{SIO0_Low();}
SIO1_High();
SIO2_High();
SIO3_High();
SetSIO0_Input();
SetSIO1_Input();
SetSIO2_Input();
SetSIO3_Input();
/* PROCEDURE: Get_Byte */
/* This procedure inputs a byte shifting in 1-bit per clock falling */
/* edge on the SIO1 pin(LSB 1st). */
unsigned char i = 0, in = 0, temp = 0;
SetSIO1_Input();
in = (in << 1); /* shift 1 place to the left or shift in 0 */
temp = PORTAbits.RA4; /* save input */
if (temp == 1) /* check to see if bit is high */
in = in | 0x01; /* if high, make bit high */
return in;
/* PROCEDURE: Get_Double_Byte */
/* This procedure inputs a byte shifting in 2-bit per clock falling */
/* edge on the SIO1 pin and SIO0 pin(MSB 1st). */
unsigned char i = 0, in = 0, temp = 0, temp1=0;
SetSIO0_Input();
SetSIO1_Input();
for (i = 0; i < 4; i++)
// temp = ((PORTF & 0x80)>>7) ; /* save input */
// temp1 = ((PORTF & 0x100)>>8); /* save input */
{in = in | 0x01;} /* if high, make bit high */
in=(in << 1);
if (temp1 == 1)
{in = in | 0x01;}
return in;
/* PROCEDURE: GetSQI_Nibble */
/* edge on the SIO0 pin, SIO1 pin, SIO2 pin and SIO3 pin. */
unsigned char in = 0, temp3 = 0, temp2 =0, temp1 = 0, temp0=0;
SetSIO0_Input();
SetSIO1_Input();
SetSIO2_Input();
SetSIO3_Input();
// temp3=((PORTF & 0x02)>>1);
//temp2=((PORTF & 0x01));
//temp1=((PORTF & 0x80)>>7);
//temp0=((PORTF & 0x100)>>8);
SCK_High();
if (temp3==1)
{in=1;}
in = (in<<1);
if (temp2==1)
{in=in|0x01;}
in = (in<<1);
if (temp1==1)
{in = in|0x01;}
in = (in<<1);
if (temp0==1)
{in = in|0x01;}
return in;
/* PROCEDURE: GetSQI_Byte */
/* This procedure call GetSQI_Nibble function twice to get 1 byte of data*/
unsigned char temp, in = 0;
in=GetSQI_Nibble();
in=(in<<4);
temp=GetSQI_Nibble();
in=in|temp;
return in;
/* PROCEDURE: Read_Status_Register */
/* This procedure reads the status register and returns the byte. */
unsigned char byte = 0;
CE_Low(); /* enable device */
SendSQI_Byte(0x05); /* send RDSR command */
SendSQI_Byte(0xff); /* send RDSR command */
byte = GetSQI_Byte(); /* receive byte */
CE_High(); /* disable device */
return byte;
unsigned char SPI_Read_Status_Register()
Send_Byte(0x05); /* send RDSR command */
byte = Get_Byte(); /* receive byte */
return byte;
/* PROCEDURE: Read_Configuration_Register */
/* This procedure reads the configuration register and returns the byte.*/
unsigned char SPI_Read_Configuration_Register()
Send_Byte(0x35); /* send RDSR command */
return byte;
unsigned char Read_Configuration_Register()
SendSQI_Byte(0x35); /* send RDSR command */
SendSQI_Byte(0xff); /* send Dummy */
return byte;
/* PROCEDURE: WREN */
/* This procedure enables the Write Enable Latch. */
void WREN()
SendSQI_Byte(0x06); /* send WREN command */
void SPI_WREN()
Send_Byte(0x06); /* send WREN command */
/* PROCEDURE: WRDI */
/* This procedure disables the Write Enable Latch. */
void WRDI()
SendSQI_Byte(0x04); /* send WRDI command */
void SPI_WRDI()
Send_Byte(0x04); /* send WRDI command */
/* PROCEDURE: QuadJ_ID */
/* This procedure Reads the manufacturer's ID, device Type and device ID. It will */
/* use AFh as the command to read the ID. */
/* Returns: */
/* ID1(Manufacture's ID = BFh, Device Type =26h , Device ID = 02h) */
SendSQI_Byte(0xAF); /* send read ID command (90h or ABh) */
SendSQI_Byte(0xFF);
Manufacturer_Id = GetSQI_Byte(); /* receive byte */
Device_Type = GetSQI_Byte(); /* receive byte */
Device_Id = GetSQI_Byte(); /* receive byte */
Send_Byte(0x9F); /* send JEDEC ID command (9Fh) */
Manufacturer_Id = Get_Byte(); /* receive byte */
Device_Type = Get_Byte(); /* receive byte */
Device_Id = Get_Byte(); /* receive byte */
/* PROCEDURE: Read */
/* This procedure reads one address of the device. It will return the */
/* byte read in variable byte. */
/* Input: */
/* Dst: Destination Address 000000H - 7FFFFFH */
Send_Byte(0x03); /* read command */
Send_Byte(((Dst & 0xFFFFFF) >> 16)); /* send 3 address bytes */
Send_Byte(((Dst & 0xFFFF) >> 8));
Send_Byte(Dst & 0xFF);
byte = Get_Byte();
return byte; /* return one byte read */
/* PROCEDURE: Read_Cont */
/* This procedure reads multiple addresses of the device and stores */
/* data into 256 byte buffer. Maximum number of bytes read is limited 256 bytes*/
/* Input: */
/* no_bytes Number of bytes to read (max = 256) */
unsigned long i = 0;
if (no_bytes>256)
{no_bytes=256;}
for (i = 0; i < no_bytes; i++) /* read until no_bytes is reached */
data_256[i] = Get_Byte();
/* PROCEDURE: HighSpeed_Read */
/* Input: */
unsigned char SPI_HighSpeed_Read(unsigned long Dst)
Send_Byte(0x0B); /* read command */
Send_Byte(0xFF); /*dummy byte*/
byte = Get_Byte();
SendSQI_Byte(0x0B); /* read command */
SendSQI_Byte(((Dst & 0xFFFFFF) >> 16)); /* send 3 address bytes */
SendSQI_Byte(((Dst & 0xFFFF) >> 8));
SendSQI_Byte(Dst & 0xFF);
SendSQI_Byte(0xAF); /*dummy byte*/
SendSQI_Byte(0xFF); /*dummy byte*/
SendSQI_Byte(0x0B);
SendSQI_Byte(0x0B);
SendSQI_Byte(0xCF); /*dummy byte*/
/* PROCEDURE: HighSpeed_Read_Cont */
/* data into 256 byte buffer. Maximum number of bytes read is limited to 256 bytes*/
/* Input: */
void SPI_HighSpeed_Read_Cont(unsigned long Dst, unsigned long no_bytes)
if (no_bytes>256)
{no_bytes=256;}
data2[i] = Get_Byte();
if (no_bytes>256)
{no_bytes=256;}
data_256[i] = GetSQI_Byte();
if (no_bytes>256)
{no_bytes=256;}
if (no_bytes>256)
{no_bytes=256;}
/* PROCEDURE: SPI_Quad_Output_Read */
/* Input: */
unsigned char SPI_Quad_Output_Read(unsigned long Dst)
Send_Byte(0x6B); /* read command */
/* PROCEDURE: SPI_Quad_Output_Read_Cont */
/* Input: */
void SPI_Quad_Output_Read_Cont(unsigned long Dst, unsigned long no_bytes)
if (no_bytes>256)
{no_bytes=256;}
/* PROCEDURE: SPI_Quad_IO_Read */
/* Input: */
unsigned char SPI_Quad_IO_Read(unsigned long Dst)
Send_Byte(0xEB); /* read command */
Send_Byte(0xEB);
Send_Byte(0xEB);
/* PROCEDURE: SPI_Quad_IO_Read_Cont */
/* Input: */
void SPI_Quad_IO_Read_Cont(unsigned long Dst, unsigned long no_bytes)
if (no_bytes>256)
{no_bytes=256;}
if (no_bytes>256)
{no_bytes=256;}
if (no_bytes>256)
{no_bytes=256;}
/* PROCEDURE: SPI_Double_Output_Read */
/* Input: */
unsigned char SPI_Double_Output_Read(unsigned long Dst)
Send_Byte(0x3B); /* read command */
byte = Get_Double_Byte();
/* PROCEDURE: SPI_Double_Output_Read_Cont */
/* Input: */
/* Returns: */
/* Nothing */
void SPI_Double_Output_Read_Cont(unsigned long Dst, unsigned long no_bytes)
if (no_bytes>256)
{no_bytes=256;}
data_256[i] = Get_Double_Byte();
/* PROCEDURE: SPI_Double_IO_Read */
/* Input: */
unsigned char SPI_Double_IO_Read(unsigned long Dst)
Send_Byte(0xBB); /* read command */
Send_Double_Byte(((Dst & 0xFFFFFF) >> 16)); /* send 3 address bytes */
Send_Double_Byte(((Dst & 0xFFFF) >> 8));
Send_Double_Byte(Dst & 0xFF);
Send_Double_Byte(0xAF); /*dummy byte*/
Send_Double_Byte(0xFF); /*dummy byte*/
/* PROCEDURE: SPI_Double_IO_Read_Cont */
/* Input: */
void SPI_Double_IO_Read_Cont(unsigned long Dst, unsigned long no_bytes)
unsigned long i=0;
if (no_bytes>256)
{no_bytes=256;}
for ( i = 0; i < no_bytes; i++) /* read until no_bytes is reached */
unsigned long i=0;
/* read command */
if (no_bytes>256)
{no_bytes=256;}
unsigned long i=0;
/* read command */
if (no_bytes>256)
{no_bytes=256;}
/* PROCEDURE: Set_Burst */
/* This procedure sets the burst length to either 8bytes or 16bytes or 32bytes or 64bytes. */
/* Input: */
/* byte: 00h,01h,02h or 03h for setting burst length */
SendSQI_Byte(0xC0); /* send Byte Program command */
SendSQI_Byte(byte); /* send byte to be programmed */
void SPI_Set_Burst(unsigned char byte)
Send_Byte(0xC0); /* send Byte Program command */
Send_Byte(byte); /* send byte to be programmed */
/* PROCEDURE: Read_Burst */
/* This procedure reads multiple (burst) address of the device. The data is stored in an array.*/
/* Input: */
unsigned int i;
i=0;
SendSQI_Byte(0x0C); /* read command */
SendSQI_Byte(Dst & 0xFF); //Dummy cycle
//if (burstlength>256)
//{burstlength=256;}
for (i=0;i<=(burstlength-1);i++)
data_256[i]=GetSQI_Byte();
void SPI_Read_Burst(unsigned long Dst, unsigned char burstlength)
unsigned int i;
i=0;
Send_Byte(0xEC); /* read command */
// {burstlength=256;}
for (i=0;i<(burstlength);i++)
/* PROCEDURE: Page_Program */
/* This procedure does page programming. The destination */
/* address should be provided. */
/* The data array of 256 bytes contains the data to be programmed. */
/* Since the size of the data array is 256 bytes rather than 256 bytes, this page program*/
/* procedure programs only 256 bytes */
/* Assumption: Address being programmed is already erased and is NOT */
/* block protected. */
/* Input: */
/* data_256[256] containing 256 bytes of data will be programmed using this function */
unsigned int i;
i=0;
SendSQI_Byte(0x02); /* send Byte Program command */
for (i=0;i<=255;i++)
{ SendSQI_Byte(data_256[i]); /* send byte to be programmed */
void SPI_Page_Program(unsigned long Dst)
unsigned int i;
i=0;
Send_Byte(0x02); /* send Byte Program command */
for (i=0;i<256;i++)
{ Send_Byte(data_256[i]); /* send byte to be programmed */
/* PROCEDURE: SPI_Quad_Page_Program */
/* Input: */
void SPI_Quad_Page_Program(unsigned long Dst)
unsigned int i;
i=0;
Send_Byte(0x32); /* send Byte Program command */
/* PROCEDURE: Chip_Erase */
/* This procedure erases the entire Chip. */
void Chip_Erase()
SendSQI_Byte(0xC7); /* send Chip Erase command (C7h) */
void SPI_Chip_Erase()
Send_Byte(0xC7); /* send Chip Erase command (C7h) */
/* PROCEDURE: Sector_Erase */
/* This procedure Sector Erases the Chip. */
/* Input: */
SendSQI_Byte(0x20); /* send Sector Erase command */
void SPI_Sector_Erase(unsigned long Dst)
Send_Byte(0x20); /* send Sector Erase command */
/* PROCEDURE: Block_Erase */
/* This procedure Block Erases 8Kbyte, 32 KByte or 64 KByte of the Chip.*/
/* Input: */
SendSQI_Byte(0xD8); /* send Block Erase command */
void SPI_Block_Erase(unsigned long Dst)
Send_Byte(0xD8); /* send Block Erase command */
/* PROCEDURE: NoOp */
/* No operation is performed. */
void NoOp()
SendSQI_Byte(0x00);
void SPI_NoOp()
Send_Byte(0x00);
/* PROCEDURE: ResetEn */
/* This procedure Enables acceptance of the RST (Reset) operation. */
void ResetEn()
SendSQI_Byte(0x66);
void SPI_ResetEn()
Send_Byte(0x66);
/* PROCEDURE: Reset */
/* This procedure resets the device in to normal operating Ready mode. */
void Reset()
SendSQI_Byte(0x99);
void SPI_Reset()
Send_Byte(0x99);
/* PROCEDURE: En_QIO */
/* This procedure enables quad I/O operation. */
void En_QIO()
Send_Byte(0x38);
/* PROCEDURE: Reset_QIO */
/* This procedure resets the device to 1-bit SPI protocol operation. */
void Reset_QIO()
SendSQI_Byte(0xff);
void SPI_Reset_QIO()
Send_Byte(0xff);
/* PROCEDURE: Write_Suspend */
/* This procedure suspends Program/Erase operation. */
SendSQI_Byte(0xb0);
void SPI_Write_Suspend()
Send_Byte(0xb0);
/* PROCEDURE: Write_Resume */
/* This procedure resumes Program/Erase operation. */
void Write_Resume()
SendSQI_Byte(0x30);
void SPI_Write_Resume()
Send_Byte(0x30);
/* PROCEDURE: Write_Status_Register */
void Write_Status_Register(unsigned int data1, unsigned char datalen)
{ //For data1 - top 8 bits are status reg bits , lower 8 bits are configuration reg bits
SendSQI_Byte(0x01);
SendSQI_Byte((data1>>8)&0xff);
if (datalen==2)
SendSQI_Byte((data1)&0xff);
void SPI_Write_Status_Register(unsigned int data1, unsigned char datalen)
Send_Byte(0x01);
Send_Byte((data1>>8)&0xff);
if (datalen==2)
Send_Byte((data1)&0xff);
/* PROCEDURE: ReadSID (Read Security ID) */
/* This procedure reads the security ID */
unsigned long i;
i=0;
if (security_length>2048)
{ security_length=2048;}
SendSQI_Byte(0x88);
SendSQI_Byte((Dst>>8) & 0xFF);
SendSQI_Byte(Dst & 0xFF); //dummy
for (i=0;i<security_length;i++)
*security_ID = GetSQI_Byte();
++security_ID;
void SPI_ReadSID(unsigned char *security_ID, unsigned long Dst, unsigned long security_length)
unsigned long i;
i=0;
Send_Byte(0x88);
Send_Byte((Dst>>8) & 0xFF);
Send_Byte(Dst & 0xFF); //dummy
*security_ID = Get_Byte();
security_ID++;
/* PROCEDURE: ProgSID (Program Security ID) */
/* This procedure programs the security ID */
unsigned long i;
i=0;
if (security_length>256)
{ security_length=256;}
SendSQI_Byte(0xa5);
SendSQI_Byte(*security_ID);
security_ID++;
void SPI_ProgSID(unsigned char *security_ID, unsigned long Dst, unsigned long security_length)
unsigned long i;
i=0;
Send_Byte(0xa5);
Send_Byte(*security_ID);
security_ID++;
/* PROCEDURE: LockSID */
/* This procedure Locks the security ID setting */
void LockSID()
SendSQI_Byte(0x85);
void SPI_LockSID()
Send_Byte(0x85);
/* PROCEDURE: ReadBlockProtection */
/* This procedure reads block protection register */
unsigned int i;
i=0;
SendSQI_Byte(0x72);
SendSQI_Byte(0xff);
for (i=6;i>0;i--)
{ block_protection_6[i-1] = GetSQI_Byte();
void SPI_ReadBlockProtection()
unsigned char i;
i=0;
Send_Byte(0x72);
for (i=6;i>0;i--)
{ block_protection_6[i-1] = Get_Byte();
/* PROCEDURE: WriteBlockProtection */
/* This procedure writes to block protection register */
unsigned char i;
i=0;
SendSQI_Byte(0x42); /* read command */
for (i=6;i>0;i--)
SendSQI_Byte(block_protection_6[i-1]);
void SPI_WriteBlockProtection()
unsigned char i;
i=0;
Send_Byte(0x42); /* read command */
for (i=6;i>0;i--)
Send_Byte(block_protection_6[i-1]);
/* PROCEDURE: Global Block Protection Unlock */
/* This procedure clears all block protection */
Send_Byte(0x98); /* read command */
SendSQI_Byte(0x98); /* read command */
/* PROCEDURE: LockBlockProtection */
/* This procedure locks the block protection register */
SendSQI_Byte(0x8d); /* read command */
void SPI_LockBlockProtection()
Send_Byte(0x8d); /* read command */
/* PROCEDURE: Non Volatile Write Lock Protection */
void NonVolWriteLockProtection()
unsigned char i;
i=0;
SendSQI_Byte(0xE8); /* read command */
for (i=6;i>0;i--)
void SPI_NonVolWriteLockProtection()
unsigned char i;
i=0;
Send_Byte(0xE8); /* read command */
for (i=6;i>0;i--)
/* PROCEDURE: Wait_Busy */
/* This procedure waits until device is no longer busy (can be used by */
/* Byte-Program, Page-Program, Sector-Erase, Block-Erase and Chip-Erase).*/
void Wait_Busy()
{char Read_byte = 0x81;
while (((Read_byte & 0x81) == 0x81) || ((Read_byte & 0x81) == 0x80) || ((Read_byte & 0x81) == 0x01)) // waste time until not busy
Read_byte = Read_Status_Register();
void SPI_Wait_Busy()
while ((SPI_Read_Status_Register()& 0x80) == 0x80) // waste time until not busy
SPI_Read_Status_Register();
/* PROCEDURE: SPI_SFDP_Read */
/* This procedure reads SFDP Table. */
Send_Byte(0x5A); /* read command */
byte = Get_Byte();
/* Main Function*/
int main()
unsigned char Read_byte;
unsigned long Dest_address, tempdata1;
unsigned long m,i,j,k,highest_address, tempdatalong;
int check,tempcheck,status;
int tempdata;
unsigned char Read_Stat_Reg,devicedata ;
unsigned char Led_Stat, tempbyte1, tempbyte2;
unsigned char sec_id[2048];
unsigned char *pntrsec_id;
unsigned long counter;
int n;ja
//SIO1_High();
TRISAbits.TRISA8=1;
n=0;
i=0;
j=0;
Led_Stat=0x00;
// Read_Stat_Reg=0x00;
status=1; //1 means memory/code works and 0 means fault has occured.
check=0; //keeps track of code progress.
tempcheck=1;
//highest_address=0x1ffffff;
highest_address=0x1FFFF;
deviceaddress=0;
devicedata=0;
Sw=0;
// Portassign();
CE_High();
//WP_High();
//Reset_Hold_High();
init();
TRISCbits.TRISC4=0;
// TRISGbits.TRISG7=0;
// PORTGbits.RG7=0;
i=0;
while (i<=0xFFFF)
//DisplayLED(0xFF);
i++;
//DisplayLED(0x00);
SPI_WREN();
tempdatalong=SPI_Read_Status_Register();
tempdatalong = tempdatalong<<8;
tempdatalong = tempdatalong |(0x82);
// tempdatalong = tempdatalong & ~(0x02);
SPI_Write_Status_Register(tempdatalong, 2);
tempdata=SPI_Read_Configuration_Register();
// Test Jedec ID
/************* 1a. Test Jedec ID *********/
Jedec_ID_Read();
if ((Manufacturer_Id == 0xbf)&& (Device_Type==0x26) && (Device_Id==0x41)&&(status==1))
{check=(check + 1);}
else
{check=0;}
// DisplayLED(check);
/************* 2a. Page program whole chip using SPI protocol and verify its OK. *********/
i=0;
while (i<=255)
data_256[i]=170;
i++;
SPI_WREN();
block_protection_6[0]=0x00;
block_protection_6[1]=0x00;
block_protection_6[2]=0x00;
block_protection_6[3]=0x00;
block_protection_6[4]=0x00;
block_protection_6[5]=0x00;
SPI_WriteBlockProtection();
SPI_Wait_Busy();
SPI_WREN();
SPI_Chip_Erase(); //Erase the chip
SPI_Wait_Busy();
i=0;
SPI_WREN();
while(i<highest_address)
{ SPI_WREN();
//DisplayLED(5);
SPI_Page_Program(i);
SPI_Wait_Busy();
i=i+256;
SPI_WREN();
j=0;
while(j<highest_address)
SPI_HighSpeed_Read_Cont(j, 64);
for (i=0;i<64;i++)
if (data_256[i]==170)
{tempcheck&=1;
else
{ tempcheck=0;
j=j+64;
if ((tempcheck == 1)&&(status==1))
{check=(check+1);
status=status&1;}
else
{status=0;}
/************* 3a. Do Sector Erase and verify that the sector is erased *********/
SPI_WREN();
SPI_Sector_Erase(0); //Do Sector Erase
SPI_Wait_Busy();
j=0;
while (j<(4096))
SPI_WREN();
SPI_Set_Burst(0x03);
SPI_Read_Burst(j, 64);
for (k=0;k<63;k++)
if (data_256[k]==0xff) // Verify that the values are correct
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
j=4096;
while (j<(4096*2))
SPI_WREN();
for (k=0;k<63;k++)
if (data_256[k]==0xAA) // Verify that the values are correct
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
{check=(check+1);
status=status&1;}
else
{status=0;}
/************* 4a. Block Erase and verify that the Block is erased *********/
SPI_WREN();
SPI_Block_Erase(0); //Do Sector Erase
SPI_Wait_Busy();
j=0;
while (j<(0x2000))
SPI_WREN();
for (k=0;k<63;k++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
j=0x2000;
while (j<(0x3000))
SPI_WREN();
for (k=0;k<63;k++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
{check=(check+1);
status=status&1;}
else
{status=0;
check|=0x44;}
/************* 5a. Chip Erase and Verify Chip is erased*********/
SPI_WREN();
SPI_Chip_Erase(); //Do Sector Erase
SPI_Wait_Busy();
j=0;
while (j<highest_address)
SPI_WREN();
for (k=0;k<63;k++)
if (data_256[k]==0xFF) // Verify that the values are correct
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
{check=(check+1);
status=status&1;}
else
{status=0;}
// Test Quad J-ID
/************* 1b. Test Quad ID *********/
Manufacturer_Id=0x00;
Device_Type=0x00;
Device_Id=0x00;
En_QIO(); //Serial Quad IO is now enabled
WREN();
QuadJ_ID_Read();
{check=(check+1);
status=status&1;}
else
{status=0;}
//DisplayLED(check);
/****** 2b. Page program whole chip using SQI protocol and verify its OK *****/
i=0;
while (i<=255)
data_256[i]=170;
i++;
WREN();
Wait_Busy();
WREN();
Wait_Busy();
WREN();
i=0;
{ WREN();
Page_Program(i);
Wait_Busy();
i=i+256;
WREN();
j=0;
Set_Burst(0x03);
Read_Burst(j, 64); //verify that it got programmed.
Wait_Busy();
for (i=0;i<64;i++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
{check=(check+1);
status=status&1;}
else
{status=0;}
/************* 3b. Sector Erase and Verify sector is erased*********/
WREN();
Wait_Busy();
j=0;
while (j<(4096))
WREN();
Set_Burst(0x03);
Read_Burst(j, 64);
for (k=0;k<63;k++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
j=4096;
while (j<(4096*2))
WREN();
Set_Burst(0x03);
Read_Burst(j, 64);
for (k=0;k<63;k++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
{check=(check+1);
status=status&1;}
else
{status=0;
check|=0x44;}
/************* 4b. Block Erase and verify that the Block is erased*********/
WREN();
Wait_Busy();
j=0;
while (j<(0x2000))
WREN();
Set_Burst(0x03);
Read_Burst(j, 64);
for (k=0;k<63;k++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
j=0x2000;
while (j<((0x3000)))
WREN();
Set_Burst(0x03);
Read_Burst(j, 64);
for (k=0;k<63;k++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
{check=(check+1);
status=status&1;}
else
{status=0;
check|=0x44;}
/************* 5b. Chip Erase and verify chip is erased *********/
WREN();
Wait_Busy();
j=0;
WREN();
Set_Burst(0x03);
Read_Burst(j, 64);
for (k=0;k<63;k++)
{tempcheck&=1;}
else
{ tempcheck=0;}
j=j+64;
{check=(check+1);
status=status&1;}
else
{status=0;}
ResetEn();
Reset();
/***************** End of checking ******/
Led_Stat=check;
if (status==0) //means a failure has occured
Led_Stat|=0x80;
while(1)
// DisplayLED(Led_Stat);
return 0;
