renga92
Member level 5
hello everyone,
i am doing a project on countdown timer (0 - 99) min and i am also counting the total hours of its working time. i am saving the no of hours and mins in eeprom for every count down of the timer.
i ran into a problem when i want to increment value greater than 255 (no of hours) and i end up getting a weird value[ the increment function fine till i shutdown the timer and turn it on,after turning it on i get weird values ]. i got the reason for getting that weird value...
if the no is 312 after saving it to eeprom. then i did turn it off and then i turned it on ,checked the value stored in the eeprom. it was still 312.
then i set the timer for any time after turning on (for example : 4 mins)
after 4 mins value turns out to be 057
the reason was that
312 binary equivalent - 1 00111000
57 binary equivalent - 0 00111001
so the ninth bit is set in the first bit.
the reason is i am working with 8 bit controller...
now my question is
1)how to work with nos greater than 255 ?
2)will that overflow in w register call any stack or will it cause any interrupt ?
i am asking this because i am using 5 to 6 functions which might also occupy most of the stack all the time...
please help me to solve this problem..
thanks in advance
renga92
the reason was that
now my question is
thanks in advance
renga92
