can't find control signal error
nvm
Hello,
I have the following piece of code that i can simulate in libero. But when I go to compile it I get the error
"Can't find control signal for tmp"
I don't know how I would go by fixing it. Please help me out and thank you for your time.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity counter is
  port(C, CLR : in  std_logic;
		shiftdone : in std_logic;
		powergood : in std_logic;
		done : out std_logic;
		reset : in std_logic;
   		Q : out std_logic_vector(15 downto 0);
		K : out std_logic_vector(15 downto 0));
end counter;
architecture archi of counter is
  signal tmp: std_logic_vector(15 downto 0);
  begin
      process (C, CLR)
		variable do : std_logic;
		begin
		if reset= '1' then
			done <= '0';
			do := '0';
		else
		  if falling_edge(clr)  then
				k <= tmp;
				done <= '1';
				do := '1';
		  elsif  (clr = '0' )  then
				if do = '1' then
				done <= '1';
				else
				done <= '0';
				end if;
				tmp <= "0000000000000000";
		  elsif (clr = '1') then
				done <= '0';
          	if (C'event and C='1'  and powergood = '1' ) then
            	tmp <= tmp + 1;
          	end if;
	 	  end if;
		end if;
      end process;
      Q <= tmp;
end archi;
Refer to the templates for synthesizable edge sensitive sequential logic in a VHDL text book.
In the present code, two conflicting clock edge expressions for the assignments to signal tmp exist.
Also the combination of edge- and level sensitive conditions for signal clr isn't synthesizable.
Reactions: nvm
    nvm
