can't define verilog module
siva_7517
Full Member level 2
icfb verilog®-xl
hi all,
There is a error when import my optimized design to icfb. Because of this error, i cant open verilog xl to do gate level simulation. need some idea's on this.
siva
jjww110
Full Member level 5
china
define verilog
please give more detail message!!
aji_vlsi
Advanced Member level 2
Bangalore, India
siva_7517 said:
hi all,
siva
What is the error message? Simply saying "There is a error " - doesn't give a hint.
Learn how to ask the right questions to get the right answer/help.
Ajeetha
www.noveldv.com
siva_7517
Full Member level 2
hi guys,
Sorry for not including the error statement.
There is an error statement in icfb log file when i have import my optimized verilog design to icfb. There error statement is:
Verilog defination for module INVX1 was not found. Using lib 'silterra18' cell 'INVX1' view 'symbol' as its symbol
Because of this statement i cant open this verilog design file in verilog xl to do a gate level simulation.
Siva
aji_vlsi
Bangalore, India
siva_7517 said:
hi guys,
Siva
Siva,
I've not used icfb etc. But looking at name of this INVX1, it is clear that it is an inverter. For plain Verilog sim, it is trivial to define it yourself and pass it as additional file to VXL.
module INVX1(..); // input/output
assign my_out = ~my_in;
endmodule
Of-course best will be to fix your flow (via icfb).
Regards
Ajeetha
www.noveldv.com
leeenghan
There are 2 parts to the answer to your question.
1. When you read a verilog netlist into icfb, you need to define the reference library that contain the standard cell (e.g. INVX1).
2. You do not need to read the verilog netlist into icfb to do simulation. I think nobody does this. You just run you simulation outside icfb environment. What do you wish to achieve by reading the netlsit into icfb that you cannot achieve by not doing this step?
Regards,
Eng Han
www.eda-utilities.com
