Cannot resolve indexed name as type ieee.std_logic_1164.std_logic_vector
anonymous.
Junior Member level 3
I have a component with generic.
component DCache_SinglePortRam is
		generic (Width : integer := 32;
			 Length : integer:= 256);
		port(Clk: in std_logic;
	    	     WordLine : in std_logic_vector(Length-1 downto 0);
	    	     DataIn : in std_logic_vector (Width-1 downto 0);
	    	     DataOut : out std_logic_vector (Width-1 downto 0);
	    	     RW : in std_logic);
	end component;
and I have those signals defined :
	signal LRU_BankRead : std_logic_vector(NumOfPorts-1 downto 0);
	signal LRU_BankWrite : std_logic_vector(NumOfPorts-1 downto 0);
Sometimes I need to use the component with the generic Width = 1 as follows :
LRUBank : DCache_SinglePortedRam
				generic map(1,LengthOfBank)
				port map(Clk,WordLines(i),LRU_BankWrite(i),LRU_BankRead(i),LRU_RW(i));
which when compiling in modelsim results in this error for LRU_BankWrite and LRU_BankRead signals (or places in the port map):
I have encountered this error before and solved it by using a different component with std_logics and no generics instead of std_logic_vectors.
unfortunately this is not possible here, Is there any other way around it ?
You're not showing what Wordlines(i) is. Is WordLines an array of std_logic_vectors? Not sure you can do that since you've dimensioned WordLines in the component using a generic. That may just be a limitation of VHDL. Does this only fail when you use "1" for your width? I've run into problems (specifically with vendor IP) where they'll have
x=std_logic_vector(0 downto 0);
which would cause compile failures.
Maybe something like this would work:
dummy:std_logic_vector(width-1 downto 0);
dummy<=Wordlines(i);
port map(Clk, dummy...)
BTW, you need a better name than "anonymous".
which is the relation between "NumberOfPorts" and "Width"?
