Cannot pass char parameter to a function.
Francesco cembrola
Newbie level 6
The code below works OK.
It calles the function 'text_pos' an passes ascii caracters to it.
Then 'text_pos' convert them to ascii codes.
These are send to the I2C interface to controll an LCD display.
These characters represent the cursor coordinates on the LCD display
However I need to modify the code to pass parameters like : text_pos ('34',65'), (two digits).
otherwise I can only get the coordinates up to 9X,9Y.
If I call the function like: text_pos('10','12'), how do I read each of the digit indivually?
I need to assign something like: int X0= first digit of row. int X1= second digit of row.
int Y0=first digit of col. int Y1 = second digit of col.
Do i need to declare two arrayes in the function?
I have tried some experiments with out success.
Can you please help to modify the code?
Thank you.:-?
#include <p18F26k22.h>
#include <stdlib.h>
#include <delays.h>
#include <stdio.h>
#include <I2C.h>
#include <string.h>
void text_pos(char row, char col);
int xpos=0;
int ypos=0;
void main(void)
text_pos('5','9');  // call function to set cursor coordinates
void text_pos(char row,char col)
xpos=col;// convert char to int
// xpos second digit
ypos=row;
// ypos second digit
StartI2C2();
putcI2C2(0x64);   //device address
putcI2C2(27);     //esc
putcI2C2(91);     // [
putcI2C2(ypos);   //row
// putcI2C2(ypos);// need here the second digit for y pos
putcI2C2(59);     // ;
putcI2C2(xpos);   // column
// putcI2C2(xpos2); //need here the second digit for X pos
putcI2C2(72);      // H
Delay10KTCYx(100);
StopI2C2();
You can only pass an array pointer to the function (this is C right?)
char my_array[]="123456";
void my_function(char *array_p)
char a,b,c;
  a=array_p[0];    // this is the first char of the array
  b=array_p[1];    // this is the second char of the array
  c=array_p[2];    // this is the third char of the array
Call it using
my_function(my_array);
If you want you can use two or more pointer parameters
char a,b,c;
Call it using
Hi thank you for the speedy replay.
I think you have over estimated my knoledge of C.
I do understand the first part of your code.
But I still don get it how to read those digits once they have been passed to the function.
Regards
Francesco
Code C - [expand]
8
9
10
11
12
char my_array[]="123456";   // I declare an array
void my_function(char *array_p)  // declaring a function that takes a char pointer as a parameter
char a,b,c;  // declare local char variables a,b,c
  a=array_p[0];    // assign to a the first character of the array (in this example '1')
  b=array_p[1];    // assign to a the second character of the array  (in this example '2')
  c=array_p[2];    // assign to a the third character of the array  (in this example '3')
my_function(my_array);  // call the function using the address of the first character of the array, my_array is the same as &my_array[0]
Code C - [expand]
8
9
10
11
12
Hi alex,
thanks agoin for the replay.
I will be modifying may code tomorrow following your example. I will post my outcome.
regards
francesco:)
