cannot back annotate in OrCad Layout Plus
pavel47
Member level 4
Switzerland
Hello
I cannot back annotate from Layout.
I swaped in layout 2 gates from 2 different components of the same type.
When I try to back annotate, I receive the message:
External pin swap (U2.7 and U1.7) not supported.
The same message for other 2 pins of gate.
So, I can't annotate to capture the gate's swapping from 2 different components???
Thanks in advance.
Pavel.
is an historical problem of orcad. The backannotate ones do not work. If You want to avoid problems you council not to use this function. [/quote]
