Cancel background Worker c sharp
Ilia Gildin
Junior Member level 3
hello
I have the following code
        private void button26_Click(object sender, EventArgs e)
            button1.Enabled = false;
            button2.Enabled = false;
            button3.Enabled = false;
            button4.Enabled = false;
            button5.Enabled = false;
            button8.Enabled = false;
            button14.Enabled = false;
            button6.Enabled = false;
            button7.Enabled = false;
            button9.Enabled = false;
            button10.Enabled = false;
            button11.Enabled = false;
            button12.Enabled = false;
            button17.Enabled = false;
            button13.Enabled = false;
            button19.Enabled = false;
            button20.Enabled = false;
            button18.Enabled = false;
            button23.Enabled = false;
            button16.Enabled = false;
            button15.Enabled = false;
            button21.Enabled = false;
            button24.Enabled = false;
            button22.Enabled = false;
            button25.Enabled = false;
            button26.Enabled = false;
            if (backgroundWorker1.IsBusy != true)
                // Start the asynchronous operation.
                backgroundWorker1.RunWorkerAsync();
        private void backgroundWorker1_DoWork(object sender, DoWorkEventArgs e)
            //NOTE: we shouldn't use a try catch block here (unless you rethrow the exception)
            //the backgroundworker will be able to detect any exception on this code.
            //if any exception is produced, it will be available to you on
            //the RunWorkerCompletedEventArgs object, method backgroundWorker1_RunWorkerCompleted
            //try
            DateTime start = DateTime.Now;
            int y = Convert.ToInt16(textBox28.Text);
            Int16 g = Convert.ToInt16(textBox27.Text);
            int i = y;
            while (i > 0)
                        if ((backgroundWorker1.CancellationPending == true))
                            e.Cancel = true;
                            break;
                        byte[] b = new byte[1] { Convert.ToByte(textBox13.Text) };
                        byte[] bytesToSend = new byte[3] { 0x4D, 0x54, 0X55 };
                        byte[] rv = new byte[bytesToSend.Length + 1];
                        System.Buffer.BlockCopy(bytesToSend, 0, rv, 0, bytesToSend.Length);
                        System.Buffer.BlockCopy(b, 0, rv, bytesToSend.Length, b.Length);
                        byte[] rw = new byte[rv.Length + 1];
                        System.Buffer.BlockCopy(rv, 0, rw, 0, rv.Length);
                        System.Buffer.BlockCopy(EOF, 0, rw, rv.Length, EOF.Length);
                        toolStripStatusLabel1.Text = BitConverter.ToString(rw);
                        Console.WriteLine(BitConverter.ToString(rw));
                            e.Cancel = true;
                            break;
                        //this.serialPort1.Write(rw, 0, rw.Length);
                        string s;
                        //s = this.serialPort1.ReadLine();
                        //s = s.TrimEnd('\r', '\n');
                        // label13.Text = s;
                        //if cancellation is pending, cancel work.
                            e.Cancel = true;
                            break;
                        System.Threading.Thread.Sleep(g);
                        byte[] b1 = new byte[1] { Convert.ToByte(textBox14.Text) };
                        byte[] bytesToSend1 = new byte[3] { 0x4D, 0x54, 0X44 };
                        byte[] rv1 = new byte[bytesToSend1.Length + 1];
                        System.Buffer.BlockCopy(bytesToSend1, 0, rv1, 0, bytesToSend1.Length);
                        System.Buffer.BlockCopy(b1, 0, rv1, bytesToSend1.Length, b1.Length);
                        byte[] rw1 = new byte[rv1.Length + EOF.Length];
                        System.Buffer.BlockCopy(rv1, 0, rw1, 0, rv1.Length);
                        System.Buffer.BlockCopy(EOF, 0, rw1, rv1.Length, EOF.Length);
                        Console.WriteLine(BitConverter.ToString(rw1));
                        toolStripStatusLabel1.Text = BitConverter.ToString(rw1);
                        //this.serialPort1.Write(rw1, 0, rw1.Length);
                        string s1;
                        //s1 = this.serialPort1.ReadLine();
                        // s1 = s1.TrimEnd('\r', '\n');
                        //  label13.Text = s1;
                        i = i - 1;
                            e.Cancel = true;
                            break;
        private void backgroundWorker1_RunWorkerCompleted(object sender,
    RunWorkerCompletedEventArgs e)
            if (e.Cancelled)
                MessageBox.Show("The task has been cancelled.");
                button2.Enabled = true;
                button4.Enabled = true;
                button5.Enabled = true;
                button8.Enabled = true;
                button14.Enabled = true;
                button6.Enabled = true;
                button7.Enabled = true;
                button9.Enabled = true;
                button10.Enabled = true;
                button11.Enabled = true;
                button12.Enabled = true;
                button17.Enabled = true;
                button13.Enabled = true;
                button19.Enabled = true;
                button20.Enabled = true;
                button18.Enabled = true;
                button23.Enabled = true;
                button16.Enabled = true;
                button15.Enabled = true;
                button21.Enabled = true;
                button24.Enabled = true;
                button22.Enabled = true;
                button25.Enabled = true;
                button26.Enabled = true;
            else if (e.Error != null)
                MessageBox.Show("Error.");
            else
                MessageBox.Show("The task has been completed.");
        private void button27_Click(object sender, EventArgs e)
            //notify background worker we want to cancel the operation.
           //this code doesn't actually cancel or kill the thread that is executing the job.
            backgroundWorker1.CancelAsync();
and my problem is that no meter how much I will press the button27 it wont stop until the while loop is finished and then I get the The task has been completed message. the backgroundworker1 settings are Generate member = true, Modifiers = private, WorkersReportsProgress = true,
WorkersSuportsCancellation = true, Dowork = backgroundWorker1_DoWork,
RunWorkerCompleted = backgroundWorker1_RunWorkerCompleted
I dont activate the back ground worker anywhere else so what can be my problem?
p.s
I wont paste my whole program here as it takes 1000 lines
please help
