Can you send different parameters to serial port?
nex
Member level 4
Tarnaveni, Romania
parameters...
Is it possible to send different parameters (like: kernel processor usage, free memory, file system parameters, etc...) to serial port ?
Cheers !
Re: parameters...
I can't understand what you want to do... Can you detail your problem?
Re: parameters...
microchaos said:
I want to display those parameters to a lcd display, after the OS start :)
Hope this give you an ideea :)
Cheers !
Re: parameters...
Ok, one more question. You don't know how to get these parameters from OS or you don't know how to send and display them?
My vision:
You wrote the program, which gets these parameters from system, put it in startup. When system starts, your program gets parameters and sends them via rs232 (lpt, usb etc) to a module which consists from microcontroller (PIC, MSP, etc) and LCD. You need a microcontroller to communicate with PC. So, controller gets the data from PC and displays them to LCD.
Sorry for my bad english :oops: but I hope, you understand ;)
Good luck!
Re: parameters...
Good luck!
Hi microchaos,
Right, you understand perfect what I want to do :)
The problem is to get those parameters, not to display :)
Cheers !
PS No problem with the english :) English isn't my native language :)
Re: parameters...
Hi Nex one more time,
Most of system parameters you can get from registry (in Win ;) ). For instance this procedure returns the frequency of CPU in MHz:
DWORD CPUFreqFromReg()
HKEY hKey;
DWORD dwBuff;
LONG lreg;
DWORD dwfreq;
lreg = RegOpenKeyEx(HKEY_LOCAL_MACHINE, "Hardware\\Description\\System\\CentralProcessor\\0", 0, KEY_READ, &hKey);
if(lreg == ERROR_SUCCESS)
dwBuff = sizeof(DWORD);
lreg = RegQueryValueEx(hKey, "~MHz", NULL, NULL, (LPBYTE)(&dwfreq), &dwBuff);
RegCloseKey (hKey);
if(lreg != ERROR_SUCCESS)
dwfreq = 0;
return dwfreq;
For the CPU ussage try this link:
hxxp://www.google.lt/search?q=cache:84B48FRl_ZcJ:codeproject.com/system/cpuusage.asp+%22get+cpu+usage%22+c%2B%2B&hl=lt&ie=UTF-8
You should refer to MSDN and Google too ;)
My best regards to Rumunia! ;)
Re: parameters...
If you can read russish, you can try this link: w*w.proglib.ru
Cheers!
Re: parameters...
I just found this link:
h**p://w*w.proglib.ru/detail.asp?id=946
I think there will be a good starting point for you.
Re: parameters...
I can't download that file, thanks anyway :)
I'll try later :)
Cheers !
