Can you saturate a voltage meter?
Mica188
Member level 2
Voltage meter
Is it possible that we can satured a voltage meter? I mean that an overload of high voltage through the voltage meter.
Thanks,
Mica
Re: Voltage meter
Usually voltage meters have high input impedance - 1MΩ serial resistor is pretty common, followed by an external/internal overvoltage/reverse voltage protection circuit, so even if you apply higher voltage than the selected range the voltmeter will show out-of-range condition but if you remove that voltage it will return to "zero" state ..
Regards,
IanP
