It looks like a 0.1 ohm resistor from Bourns. Check the physical size against Bourns web site: https://www.bourns.com/ProductLine.aspx?name=pulse_power_resistors
Keith
It says R100 which is why I think it is 0.1 ohm. The link I gave shows several resistors which look the same but as you didn't give dimensions I cannot say exactly which.
Keith
A 0.5W resistor would be able to work up to about 3 amps to be within spec. (calculated for 0.05 ohm)
