Re: Can you give some advice on suppress noise from regulato
Big capacitor is not possible. Its will be at least several hundrd uF and i can't place it.
If suppress is impossible with brief circiuts, can I design a simple discrete transistor regulator to instead 723? I don't care about many things like the low differential voltage, accurate voltage value and low-temperature drift, which is required in monolithic voltage regulators. Where can i get such circuits to learn from?
