Can we use timer ? simultaneously along with CCP Module ?
asking
Full Member level 5
Hello friends,
Actually i want to ask question regarding PWM function using CCP Module of PIC16F628A. Once i have generated 38.3KHZ for my TSOP Application, is it possible to use timers without interrupting the PWM output ? Actually i need timer to count the Frequency received on TSOP1838 Module. But as i read datasheet its written all the Three characters Compare Capture PWM features uses different timer ? so which one i used after generating PWM using the mikroc PIC Pro library ? Timer0 or Timer1 ? will be available without disturbing PWM output ?
