Can We Replace PIC16F72 with PIC16F73
rahul_sanghavi
Member level 2
pic16f72 and pic16f73 +difference
Can i replace pic16F72 by pic 16F73?
Regards
Rahul Sanghavi
UroBoros
Advanced Member level 2
Cochin - India
pic16f73 adc not working
Hai
72 is 2k ROM
73 is 4k
rest almost same .
refer datasheet weather any peripherals are different.
Almost similer pin compatable
Picstudent
rahul_sanghavi
Member level 2
I read data sheet both are pin compatible. Also i used ADC module in my project both are compatiable.
But i have face problem about ADC.
Is the ADC of both controller are same?
Regards
Rahul Sanghavi
IanP
Advanced Member level 5
West Coast
There are some major differencies between PIC16F72 and PIC16F73.
For example, 73 has USART, 72 doesn't, different program and data memories ..
In general, you can replace 72 with 73 but the other way around may be in some cases impossible.
As far as ADC is concerned, there is no difference between these two mcus ..
Regards,
IanP
swapgo
Full Member level 2
India
Hai
U can Do that.
But I wonder why you want to go for 73 instead of 72.
Because f72 is very cheap as compared against f73.
If you are concerned abt memory then you can go for it.
ADC is same for the both.
Regards
Gopi
