Can we make a LATCH from FLIP FLOP
spartanthewarrior
Full Member level 2
Hi All,
Can any body tell me how to make a
LATCH from FLIP - FLOP.
The main difference between gated latch and FF is that latches are level sensitive while FF are edge sensitive. They both require the use of clock signal and are used in sequential logic. For a latch, the output tracks the input when the clock signal is high, so as long as the clock is logic 1, the output can change if the input also changes. FF on the other hand, will store the input only when there is a rising/falling edge of the clock.
Read this
http://esd.cs.ucr.edu/labs/tutorial/
http://en.wikipedia.org/wiki/Latch_(electronics)
if the clock frequency is exactly equal to (setup+hold) time duration then the FF and latch.
Thanks & Regards,
Sri.
Added after 1 minutes:
if the clock frequency is exactly equal to (setup+hold) time duration then the FF and latch are same.
Thanks & Regards,
Sri.
