pradeep_k_b
Full Member level 3
- Joined
- Dec 21, 2011
- Messages
- 160
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,306
- Location
- Nilambur, India
- Activity points
- 2,509
// File Name : servo.c
// Version : 1.0
// Description : Servo Motor Controller
// Using TIMER0 for Generating Servo PWM
// Target : PICJazz 16F690 Board
// Compiler : HITECT PICC-Lite Version 9.60PL1
// IDE : Microchip MPLAB IDE v8.00
#include <pic.h>
/* PIC Configuration Bit:
** INTIO - Using Internal RC No Clock
** WDTDIS - Wacthdog Timer Disable
** PWRTEN - Power Up Timer Enable
** MCLREN - Master Clear Enable
** UNPROTECT - Code Un-Protect
** UNPROTECT - Data EEPROM Read Un-Protect
** BORDIS - Borwn Out Detect Disable
** IESODIS - Internal External Switch Over Mode Disable
** FCMDIS - Monitor Clock Fail Safe Disable
__CONFIG(INTIO & WDTDIS & PWRTEN & MCLREN & UNPROTECT \
& UNPROTECT & BORDIS & IESODIS & FCMDIS);
// Using Internal Clock of 8 Mhz
#define FOSC 8000000L
// Servo definition and variables
#define MAX_VALUE 200
#define CCW_ROTATION MAX_VALUE - 20
#define CW_ROTATION MAX_VALUE - 10
#define STOP_ROTATION MAX_VALUE
#define THRESHOLD_VALUE 50
unsigned char pulse_max=0;
unsigned char pulse_top=0;
unsigned char top_value = 0;
static void interrupt isr(void)
if(T0IF) { // TIMER0 Interrupt Flag
pulse_max++; // Pulse Max Increment
pulse_top++; // Pulse Top Increment
/* MAX_VALUE=200 turn off the pulse */
if (pulse_max >= MAX_VALUE) {
pulse_max=0;
pulse_top=0;
RC2=0; // Turn off RC2
/* top_value = MAX_VALUE - n, n=10: 10 x 0.1ms = 1.0ms, n=20: 20 x 0.1ms = 2.0ms */
/* 2ms -> CCW Rotation, 1ms -> CW Rotation */
if (pulse_top == top_value) {
RC2=1; // Turn On RC2
TMR0 = 156; // Initial Value for 0.1ms Interrupt
T0IF = 0; // Clear TIMER0 interrupt flag
void main(void)
unsigned char ldr_left;
unsigned char ldr_right;
int ldr_diff;
OSCCON=0x70; // Select 8 Mhz internal clock
/* Initial Port Used */
TRISC = 0x03; // Set RC0 and RC1 as input others as Output
ANSEL = 0x30; // Set PORT AN4 and AN5 as analog input
ANSELH = 0x00; // Set PORT AN8 to AN11 as Digital I/O
PORTC = 0x00; // Turn Off all PORTC
/* Init Servo Pulse */
pulse_max=0;
pulse_top=0;
top_value = MAX_VALUE; // top_value = MAX_VALUE: Servo Motor Stop
/* Initial ADC */
ADCON1=0b00110000; // Select the FRC for 8 Mhz
/* Init TIMER0: Period: Fosc/4 x Prescaler x TMR0
0.0005 ms x 2 * 100 = 0.1 ms */
OPTION = 0b00000000; // 1:2 Prescaller
TMR0=156; // Interupt every 0.1 ms
T0IE = 1; // Enable interrupt on TMR0 overflow
GIE = 1; // Global interrupt enable
for(;;) {
/* Read the ADC here */
ADCON0=0b00010001; // select left justify result. ADC port channel AN4
GODONE=1; // initiate conversion on the channel 4
while(GODONE) continue; // Wait for ldr_left conversion done
ldr_left=ADRESH; // Read 8 bits MSB, Ignore 2 bits LSB in ADRESL
ADCON0=0b00010101; // select left justify result. ADC port channel AN5
GODONE=1; // initiate conversion on the channel 5
while(GODONE) continue; // Wait for ldr_right conversion done
ldr_right=ADRESH; // Read 8 bits MSB, Ignore 2 bits LSB in ADRESL
/* Get the different */
ldr_diff=ldr_left - ldr_right;
if ((ldr_diff >= -THRESHOLD_VALUE) && (ldr_diff <= THRESHOLD_VALUE)) {
top_value = MAX_VALUE; // Stop the Servo Motor
} else {
if (ldr_diff > THRESHOLD_VALUE) {
top_value = CCW_ROTATION; // Counterclockwise Rotation
} else {
top_value = CW_ROTATION; // Clockwise Rotation
/* EOF: servo.c */
#ifndef _HTC_H_
#warning Header file pic16f690.h included directly. Use #include <htc.h> instead.
#endif
/* header file for the MICROCHIP PIC microcontroller
* 16F690
#ifndef __PIC16F690_H
#define __PIC16F690_H
// Configuration mask definitions
// Config Register: CONFIG
#define CONFIG 0x2007
// Oscillator Selection bits
// RC oscillator: CLKOUT function on RA4/OSC2/CLKOUT pin, RC on RA5/OSC1/CLKIN
#define FOSC_EXTRCCLK 0xFFFF
// RCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, RC on RA5/OSC1/CLKIN
#define FOSC_EXTRCIO 0xFFFE
// INTOSC oscillator: CLKOUT function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN
#define FOSC_INTRCCLK 0xFFFD
// INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN
#define FOSC_INTRCIO 0xFFFC
// EC: I/O function on RA4/OSC2/CLKOUT pin, CLKIN on RA5/OSC1/CLKIN
#define FOSC_EC 0xFFFB
// HS oscillator: High-speed crystal/resonator on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN
#define FOSC_HS 0xFFFA
// XT oscillator: Crystal/resonator on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN
#define FOSC_XT 0xFFF9
// LP oscillator: Low-power crystal on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN
#define FOSC_LP 0xFFF8
// Watchdog Timer Enable bit
// WDT enabled
#define WDTE_ON 0xFFFF
// WDT disabled and can be enabled by SWDTEN bit of the WDTCON register
#define WDTE_OFF 0xFFF7
// Power-up Timer Enable bit
// PWRT disabled
#define PWRTE_OFF 0xFFFF
// PWRT enabled
#define PWRTE_ON 0xFFEF
// MCLR Pin Function Select bit
// MCLR pin function is MCLR
#define MCLRE_ON 0xFFFF
// MCLR pin function is digital input, MCLR internally tied to VDD
#define MCLRE_OFF 0xFFDF
// Code Protection bit
// Program memory code protection is disabled
#define CP_OFF 0xFFFF
// Program memory code protection is enabled
#define CP_ON 0xFFBF
// Data Code Protection bit
// Data memory code protection is disabled
#define CPD_OFF 0xFFFF
// Data memory code protection is enabled
#define CPD_ON 0xFF7F
// Brown-out Reset Selection bits
// BOR enabled
#define BOREN_ON 0xFFFF
// BOR enabled during operation and disabled in Sleep
#define BOREN_NSLEEP 0xFEFF
// BOR controlled by SBOREN bit of the PCON register
#define BOREN_SBODEN 0xFDFF
// BOR disabled
#define BOREN_OFF 0xFCFF
// Internal External Switchover bit
// Internal External Switchover mode is enabled
#define IESO_ON 0xFFFF
// Internal External Switchover mode is disabled
#define IESO_OFF 0xFBFF
// Fail-Safe Clock Monitor Enabled bit
// Fail-Safe Clock Monitor is enabled
#define FCMEN_ON 0xFFFF
// Fail-Safe Clock Monitor is disabled
#define FCMEN_OFF 0xF7FF
// Special function register definitions
// Register: INDF
volatile unsigned char INDF @ 0x000;
// bit and bitfield definitions
// Register: TMR0
volatile unsigned char TMR0 @ 0x001;
// Register: PCL
volatile unsigned char PCL @ 0x002;
// Register: STATUS
volatile unsigned char STATUS @ 0x003;
volatile bit CARRY @ ((unsigned)&STATUS*8)+0;
volatile bit DC @ ((unsigned)&STATUS*8)+1;
volatile bit ZERO @ ((unsigned)&STATUS*8)+2;
volatile bit nPD @ ((unsigned)&STATUS*8)+3;
volatile bit nTO @ ((unsigned)&STATUS*8)+4;
volatile bit IRP @ ((unsigned)&STATUS*8)+7;
volatile bit RP0 @ ((unsigned)&STATUS*8)+5;
volatile bit RP1 @ ((unsigned)&STATUS*8)+6;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned C : 1;
unsigned DC : 1;
unsigned Z : 1;
unsigned nPD : 1;
unsigned nTO : 1;
unsigned RP : 2;
unsigned IRP : 1;
struct {
unsigned : 5;
unsigned RP0 : 1;
unsigned RP1 : 1;
} STATUSbits @ 0x003;
#endif
// Register: FSR
volatile unsigned char FSR @ 0x004;
// Register: PORTA
volatile unsigned char PORTA @ 0x005;
volatile bit RA0 @ ((unsigned)&PORTA*8)+0;
volatile bit RA1 @ ((unsigned)&PORTA*8)+1;
volatile bit RA2 @ ((unsigned)&PORTA*8)+2;
volatile bit RA3 @ ((unsigned)&PORTA*8)+3;
volatile bit RA4 @ ((unsigned)&PORTA*8)+4;
volatile bit RA5 @ ((unsigned)&PORTA*8)+5;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned RA0 : 1;
unsigned RA1 : 1;
unsigned RA2 : 1;
unsigned RA3 : 1;
unsigned RA4 : 1;
unsigned RA5 : 1;
} PORTAbits @ 0x005;
#endif
// Register: PORTB
volatile unsigned char PORTB @ 0x006;
volatile bit RB4 @ ((unsigned)&PORTB*8)+4;
volatile bit RB5 @ ((unsigned)&PORTB*8)+5;
volatile bit RB6 @ ((unsigned)&PORTB*8)+6;
volatile bit RB7 @ ((unsigned)&PORTB*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
unsigned RB4 : 1;
unsigned RB5 : 1;
unsigned RB6 : 1;
unsigned RB7 : 1;
} PORTBbits @ 0x006;
#endif
// Register: PORTC
volatile unsigned char PORTC @ 0x007;
volatile bit RC0 @ ((unsigned)&PORTC*8)+0;
volatile bit RC1 @ ((unsigned)&PORTC*8)+1;
volatile bit RC2 @ ((unsigned)&PORTC*8)+2;
volatile bit RC3 @ ((unsigned)&PORTC*8)+3;
volatile bit RC4 @ ((unsigned)&PORTC*8)+4;
volatile bit RC5 @ ((unsigned)&PORTC*8)+5;
volatile bit RC6 @ ((unsigned)&PORTC*8)+6;
volatile bit RC7 @ ((unsigned)&PORTC*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned RC0 : 1;
unsigned RC1 : 1;
unsigned RC2 : 1;
unsigned RC3 : 1;
unsigned RC4 : 1;
unsigned RC5 : 1;
unsigned RC6 : 1;
unsigned RC7 : 1;
} PORTCbits @ 0x007;
#endif
// Register: PCLATH
volatile unsigned char PCLATH @ 0x00A;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 5;
} PCLATHbits @ 0x00A;
#endif
// Register: INTCON
volatile unsigned char INTCON @ 0x00B;
volatile bit RABIF @ ((unsigned)&INTCON*8)+0;
volatile bit INTF @ ((unsigned)&INTCON*8)+1;
volatile bit T0IF @ ((unsigned)&INTCON*8)+2;
volatile bit RABIE @ ((unsigned)&INTCON*8)+3;
volatile bit INTE @ ((unsigned)&INTCON*8)+4;
volatile bit T0IE @ ((unsigned)&INTCON*8)+5;
volatile bit PEIE @ ((unsigned)&INTCON*8)+6;
volatile bit GIE @ ((unsigned)&INTCON*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned RABIF : 1;
unsigned INTF : 1;
unsigned T0IF : 1;
unsigned RABIE : 1;
unsigned INTE : 1;
unsigned T0IE : 1;
unsigned PEIE : 1;
unsigned GIE : 1;
} INTCONbits @ 0x00B;
#endif
// Register: PIR1
volatile unsigned char PIR1 @ 0x00C;
volatile bit TMR1IF @ ((unsigned)&PIR1*8)+0;
volatile bit TMR2IF @ ((unsigned)&PIR1*8)+1;
volatile bit CCP1IF @ ((unsigned)&PIR1*8)+2;
volatile bit SSPIF @ ((unsigned)&PIR1*8)+3;
volatile bit TXIF @ ((unsigned)&PIR1*8)+4;
volatile bit RCIF @ ((unsigned)&PIR1*8)+5;
volatile bit ADIF @ ((unsigned)&PIR1*8)+6;
volatile bit T1IF @ ((unsigned)&PIR1*8)+0;
volatile bit T2IF @ ((unsigned)&PIR1*8)+1;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned TMR1IF : 1;
unsigned TMR2IF : 1;
unsigned CCP1IF : 1;
unsigned SSPIF : 1;
unsigned TXIF : 1;
unsigned RCIF : 1;
unsigned ADIF : 1;
struct {
unsigned : 1;
unsigned : 1;
unsigned : 1;
unsigned : 1;
unsigned : 2;
unsigned : 1;
struct {
unsigned T1IF : 1;
unsigned T2IF : 1;
} PIR1bits @ 0x00C;
#endif
// Register: PIR2
volatile unsigned char PIR2 @ 0x00D;
volatile bit EEIF @ ((unsigned)&PIR2*8)+4;
volatile bit C1IF @ ((unsigned)&PIR2*8)+5;
volatile bit C2IF @ ((unsigned)&PIR2*8)+6;
volatile bit OSFIF @ ((unsigned)&PIR2*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
unsigned EEIF : 1;
unsigned C1IF : 1;
unsigned C2IF : 1;
unsigned OSFIF : 1;
} PIR2bits @ 0x00D;
#endif
// Register: TMR1L
volatile unsigned char TMR1L @ 0x00E;
// Register: TMR1H
volatile unsigned char TMR1H @ 0x00F;
// Register: TMR1
volatile unsigned int TMR1 @ 0x00E;
// Register: T1CON
volatile unsigned char T1CON @ 0x010;
volatile bit TMR1ON @ ((unsigned)&T1CON*8)+0;
volatile bit TMR1CS @ ((unsigned)&T1CON*8)+1;
volatile bit nT1SYNC @ ((unsigned)&T1CON*8)+2;
volatile bit T1OSCEN @ ((unsigned)&T1CON*8)+3;
volatile bit TMR1GE @ ((unsigned)&T1CON*8)+6;
volatile bit T1GINV @ ((unsigned)&T1CON*8)+7;
volatile bit T1CKPS0 @ ((unsigned)&T1CON*8)+4;
volatile bit T1CKPS1 @ ((unsigned)&T1CON*8)+5;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned TMR1ON : 1;
unsigned TMR1CS : 1;
unsigned nT1SYNC : 1;
unsigned T1OSCEN : 1;
unsigned T1CKPS : 2;
unsigned TMR1GE : 1;
unsigned T1GINV : 1;
struct {
unsigned : 4;
unsigned T1CKPS0 : 1;
unsigned T1CKPS1 : 1;
} T1CONbits @ 0x010;
#endif
// Register: TMR2
volatile unsigned char TMR2 @ 0x011;
// Register: T2CON
volatile unsigned char T2CON @ 0x012;
volatile bit TMR2ON @ ((unsigned)&T2CON*8)+2;
volatile bit T2CKPS0 @ ((unsigned)&T2CON*8)+0;
volatile bit T2CKPS1 @ ((unsigned)&T2CON*8)+1;
volatile bit TOUTPS0 @ ((unsigned)&T2CON*8)+3;
volatile bit TOUTPS1 @ ((unsigned)&T2CON*8)+4;
volatile bit TOUTPS2 @ ((unsigned)&T2CON*8)+5;
volatile bit TOUTPS3 @ ((unsigned)&T2CON*8)+6;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned T2CKPS : 2;
unsigned TMR2ON : 1;
unsigned TOUTPS : 4;
struct {
unsigned T2CKPS0 : 1;
unsigned T2CKPS1 : 1;
unsigned : 1;
unsigned TOUTPS0 : 1;
unsigned TOUTPS1 : 1;
unsigned TOUTPS2 : 1;
unsigned TOUTPS3 : 1;
} T2CONbits @ 0x012;
#endif
// Register: SSPBUF
volatile unsigned char SSPBUF @ 0x013;
// Register: SSPCON
volatile unsigned char SSPCON @ 0x014;
volatile bit CKP @ ((unsigned)&SSPCON*8)+4;
volatile bit SSPEN @ ((unsigned)&SSPCON*8)+5;
volatile bit SSPOV @ ((unsigned)&SSPCON*8)+6;
volatile bit WCOL @ ((unsigned)&SSPCON*8)+7;
volatile bit SSPM0 @ ((unsigned)&SSPCON*8)+0;
volatile bit SSPM1 @ ((unsigned)&SSPCON*8)+1;
volatile bit SSPM2 @ ((unsigned)&SSPCON*8)+2;
volatile bit SSPM3 @ ((unsigned)&SSPCON*8)+3;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned SSPM : 4;
unsigned CKP : 1;
unsigned SSPEN : 1;
unsigned SSPOV : 1;
unsigned WCOL : 1;
struct {
unsigned SSPM0 : 1;
unsigned SSPM1 : 1;
unsigned SSPM2 : 1;
unsigned SSPM3 : 1;
} SSPCONbits @ 0x014;
#endif
// Register: CCPR1L
volatile unsigned char CCPR1L @ 0x015;
// Register: CCPR1H
volatile unsigned char CCPR1H @ 0x016;
// Register: CCPR
volatile unsigned int CCPR @ 0x015;
// Register: CCP1CON
volatile unsigned char CCP1CON @ 0x017;
volatile bit CCP1M0 @ ((unsigned)&CCP1CON*8)+0;
volatile bit CCP1M1 @ ((unsigned)&CCP1CON*8)+1;
volatile bit CCP1M2 @ ((unsigned)&CCP1CON*8)+2;
volatile bit CCP1M3 @ ((unsigned)&CCP1CON*8)+3;
volatile bit DC1B0 @ ((unsigned)&CCP1CON*8)+4;
volatile bit DC1B1 @ ((unsigned)&CCP1CON*8)+5;
volatile bit P1M0 @ ((unsigned)&CCP1CON*8)+6;
volatile bit P1M1 @ ((unsigned)&CCP1CON*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned CCP1M : 4;
unsigned DC1B : 2;
unsigned P1M : 2;
struct {
unsigned CCP1M0 : 1;
unsigned CCP1M1 : 1;
unsigned CCP1M2 : 1;
unsigned CCP1M3 : 1;
unsigned DC1B0 : 1;
unsigned DC1B1 : 1;
unsigned P1M0 : 1;
unsigned P1M1 : 1;
} CCP1CONbits @ 0x017;
#endif
// Register: RCSTA
volatile unsigned char RCSTA @ 0x018;
volatile bit RX9D @ ((unsigned)&RCSTA*8)+0;
volatile bit OERR @ ((unsigned)&RCSTA*8)+1;
volatile bit FERR @ ((unsigned)&RCSTA*8)+2;
volatile bit ADDEN @ ((unsigned)&RCSTA*8)+3;
volatile bit CREN @ ((unsigned)&RCSTA*8)+4;
volatile bit SREN @ ((unsigned)&RCSTA*8)+5;
volatile bit RX9 @ ((unsigned)&RCSTA*8)+6;
volatile bit SPEN @ ((unsigned)&RCSTA*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned RX9D : 1;
unsigned OERR : 1;
unsigned FERR : 1;
unsigned ADDEN : 1;
unsigned CREN : 1;
unsigned SREN : 1;
unsigned RX9 : 1;
unsigned SPEN : 1;
} RCSTAbits @ 0x018;
#endif
// Register: TXREG
volatile unsigned char TXREG @ 0x019;
// Register: RCREG
volatile unsigned char RCREG @ 0x01A;
// Register: PWM1CON
volatile unsigned char PWM1CON @ 0x01C;
volatile bit PRSEN @ ((unsigned)&PWM1CON*8)+7;
volatile bit PDC0 @ ((unsigned)&PWM1CON*8)+0;
volatile bit PDC1 @ ((unsigned)&PWM1CON*8)+1;
volatile bit PDC2 @ ((unsigned)&PWM1CON*8)+2;
volatile bit PDC3 @ ((unsigned)&PWM1CON*8)+3;
volatile bit PDC4 @ ((unsigned)&PWM1CON*8)+4;
volatile bit PDC5 @ ((unsigned)&PWM1CON*8)+5;
volatile bit PDC6 @ ((unsigned)&PWM1CON*8)+6;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned PDC : 7;
unsigned PRSEN : 1;
struct {
unsigned PDC0 : 1;
unsigned PDC1 : 1;
unsigned PDC2 : 1;
unsigned PDC3 : 1;
unsigned PDC4 : 1;
unsigned PDC5 : 1;
unsigned PDC6 : 1;
} PWM1CONbits @ 0x01C;
#endif
// Register: ECCPAS
volatile unsigned char ECCPAS @ 0x01D;
volatile bit ECCPASE @ ((unsigned)&ECCPAS*8)+7;
volatile bit PSSBD0 @ ((unsigned)&ECCPAS*8)+0;
volatile bit PSSBD1 @ ((unsigned)&ECCPAS*8)+1;
volatile bit PSSAC0 @ ((unsigned)&ECCPAS*8)+2;
volatile bit PSSAC1 @ ((unsigned)&ECCPAS*8)+3;
volatile bit ECCPAS0 @ ((unsigned)&ECCPAS*8)+4;
volatile bit ECCPAS1 @ ((unsigned)&ECCPAS*8)+5;
volatile bit ECCPAS2 @ ((unsigned)&ECCPAS*8)+6;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned PSSBD : 2;
unsigned PSSAC : 2;
unsigned ECCPAS : 3;
unsigned ECCPASE : 1;
struct {
unsigned PSSBD0 : 1;
unsigned PSSBD1 : 1;
unsigned PSSAC0 : 1;
unsigned PSSAC1 : 1;
unsigned ECCPAS0 : 1;
unsigned ECCPAS1 : 1;
unsigned ECCPAS2 : 1;
} ECCPASbits @ 0x01D;
#endif
// Register: ADRESH
volatile unsigned char ADRESH @ 0x01E;
// Register: ADCON0
volatile unsigned char ADCON0 @ 0x01F;
volatile bit ADON @ ((unsigned)&ADCON0*8)+0;
volatile bit GO_nDONE @ ((unsigned)&ADCON0*8)+1;
volatile bit VCFG @ ((unsigned)&ADCON0*8)+6;
volatile bit ADFM @ ((unsigned)&ADCON0*8)+7;
volatile bit GO @ ((unsigned)&ADCON0*8)+1;
volatile bit CHS0 @ ((unsigned)&ADCON0*8)+2;
volatile bit CHS1 @ ((unsigned)&ADCON0*8)+3;
volatile bit CHS2 @ ((unsigned)&ADCON0*8)+4;
volatile bit CHS3 @ ((unsigned)&ADCON0*8)+5;
volatile bit nDONE @ ((unsigned)&ADCON0*8)+1;
volatile bit GO_DONE @ ((unsigned)&ADCON0*8)+1;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned ADON : 1;
unsigned GO_nDONE : 1;
unsigned CHS : 4;
unsigned VCFG : 1;
unsigned ADFM : 1;
struct {
unsigned : 1;
unsigned : 1;
unsigned : 4;
unsigned : 1;
unsigned : 1;
struct {
unsigned : 1;
unsigned GO : 1;
unsigned CHS0 : 1;
unsigned CHS1 : 1;
unsigned CHS2 : 1;
unsigned CHS3 : 1;
struct {
unsigned : 1;
unsigned nDONE : 1;
struct {
unsigned : 1;
unsigned GO_DONE : 1;
} ADCON0bits @ 0x01F;
#endif
// Special function register definitions: Bank 1
// Register: OPTION_REG
volatile unsigned char OPTION_REG @ 0x081;
volatile bit PSA @ ((unsigned)&OPTION_REG*8)+3;
volatile bit T0SE @ ((unsigned)&OPTION_REG*8)+4;
volatile bit T0CS @ ((unsigned)&OPTION_REG*8)+5;
volatile bit INTEDG @ ((unsigned)&OPTION_REG*8)+6;
volatile bit nRABPU @ ((unsigned)&OPTION_REG*8)+7;
volatile bit PS0 @ ((unsigned)&OPTION_REG*8)+0;
volatile bit PS1 @ ((unsigned)&OPTION_REG*8)+1;
volatile bit PS2 @ ((unsigned)&OPTION_REG*8)+2;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned PS : 3;
unsigned PSA : 1;
unsigned T0SE : 1;
unsigned T0CS : 1;
unsigned INTEDG : 1;
unsigned nRABPU : 1;
struct {
unsigned PS0 : 1;
unsigned PS1 : 1;
unsigned PS2 : 1;
} OPTION_REGbits @ 0x081;
#endif
// Register: TRISA
volatile unsigned char TRISA @ 0x085;
volatile bit TRISA0 @ ((unsigned)&TRISA*8)+0;
volatile bit TRISA1 @ ((unsigned)&TRISA*8)+1;
volatile bit TRISA2 @ ((unsigned)&TRISA*8)+2;
volatile bit TRISA3 @ ((unsigned)&TRISA*8)+3;
volatile bit TRISA4 @ ((unsigned)&TRISA*8)+4;
volatile bit TRISA5 @ ((unsigned)&TRISA*8)+5;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned TRISA0 : 1;
unsigned TRISA1 : 1;
unsigned TRISA2 : 1;
unsigned TRISA3 : 1;
unsigned TRISA4 : 1;
unsigned TRISA5 : 1;
} TRISAbits @ 0x085;
#endif
// Register: TRISB
volatile unsigned char TRISB @ 0x086;
volatile bit TRISB4 @ ((unsigned)&TRISB*8)+4;
volatile bit TRISB5 @ ((unsigned)&TRISB*8)+5;
volatile bit TRISB6 @ ((unsigned)&TRISB*8)+6;
volatile bit TRISB7 @ ((unsigned)&TRISB*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
unsigned TRISB4 : 1;
unsigned TRISB5 : 1;
unsigned TRISB6 : 1;
unsigned TRISB7 : 1;
} TRISBbits @ 0x086;
#endif
// Register: TRISC
volatile unsigned char TRISC @ 0x087;
volatile bit TRISC0 @ ((unsigned)&TRISC*8)+0;
volatile bit TRISC1 @ ((unsigned)&TRISC*8)+1;
volatile bit TRISC2 @ ((unsigned)&TRISC*8)+2;
volatile bit TRISC3 @ ((unsigned)&TRISC*8)+3;
volatile bit TRISC4 @ ((unsigned)&TRISC*8)+4;
volatile bit TRISC5 @ ((unsigned)&TRISC*8)+5;
volatile bit TRISC6 @ ((unsigned)&TRISC*8)+6;
volatile bit TRISC7 @ ((unsigned)&TRISC*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned TRISC0 : 1;
unsigned TRISC1 : 1;
unsigned TRISC2 : 1;
unsigned TRISC3 : 1;
unsigned TRISC4 : 1;
unsigned TRISC5 : 1;
unsigned TRISC6 : 1;
unsigned TRISC7 : 1;
} TRISCbits @ 0x087;
#endif
// Register: PIE1
volatile unsigned char PIE1 @ 0x08C;
volatile bit TMR1IE @ ((unsigned)&PIE1*8)+0;
volatile bit TMR2IE @ ((unsigned)&PIE1*8)+1;
volatile bit CCP1IE @ ((unsigned)&PIE1*8)+2;
volatile bit SSPIE @ ((unsigned)&PIE1*8)+3;
volatile bit TXIE @ ((unsigned)&PIE1*8)+4;
volatile bit RCIE @ ((unsigned)&PIE1*8)+5;
volatile bit ADIE @ ((unsigned)&PIE1*8)+6;
volatile bit T1IE @ ((unsigned)&PIE1*8)+0;
volatile bit T2IE @ ((unsigned)&PIE1*8)+1;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned TMR1IE : 1;
unsigned TMR2IE : 1;
unsigned CCP1IE : 1;
unsigned SSPIE : 1;
unsigned TXIE : 1;
unsigned RCIE : 1;
unsigned ADIE : 1;
struct {
unsigned T1IE : 1;
unsigned T2IE : 1;
} PIE1bits @ 0x08C;
#endif
// Register: PIE2
volatile unsigned char PIE2 @ 0x08D;
volatile bit EEIE @ ((unsigned)&PIE2*8)+4;
volatile bit C1IE @ ((unsigned)&PIE2*8)+5;
volatile bit C2IE @ ((unsigned)&PIE2*8)+6;
volatile bit OSFIE @ ((unsigned)&PIE2*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
unsigned EEIE : 1;
unsigned C1IE : 1;
unsigned C2IE : 1;
unsigned OSFIE : 1;
} PIE2bits @ 0x08D;
#endif
// Register: PCON
volatile unsigned char PCON @ 0x08E;
volatile bit nBOR @ ((unsigned)&PCON*8)+0;
volatile bit nPOR @ ((unsigned)&PCON*8)+1;
volatile bit SBOREN @ ((unsigned)&PCON*8)+4;
volatile bit ULPWUE @ ((unsigned)&PCON*8)+5;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned nBOR : 1;
unsigned nPOR : 1;
unsigned : 2;
unsigned SBOREN : 1;
unsigned ULPWUE : 1;
} PCONbits @ 0x08E;
#endif
// Register: OSCCON
volatile unsigned char OSCCON @ 0x08F;
volatile bit SCS @ ((unsigned)&OSCCON*8)+0;
volatile bit LTS @ ((unsigned)&OSCCON*8)+1;
volatile bit HTS @ ((unsigned)&OSCCON*8)+2;
volatile bit OSTS @ ((unsigned)&OSCCON*8)+3;
volatile bit IRCF0 @ ((unsigned)&OSCCON*8)+4;
volatile bit IRCF1 @ ((unsigned)&OSCCON*8)+5;
volatile bit IRCF2 @ ((unsigned)&OSCCON*8)+6;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned SCS : 1;
unsigned LTS : 1;
unsigned HTS : 1;
unsigned OSTS : 1;
unsigned IRCF : 3;
struct {
unsigned : 4;
unsigned IRCF0 : 1;
unsigned IRCF1 : 1;
unsigned IRCF2 : 1;
} OSCCONbits @ 0x08F;
#endif
// Register: OSCTUNE
volatile unsigned char OSCTUNE @ 0x090;
volatile bit TUN0 @ ((unsigned)&OSCTUNE*8)+0;
volatile bit TUN1 @ ((unsigned)&OSCTUNE*8)+1;
volatile bit TUN2 @ ((unsigned)&OSCTUNE*8)+2;
volatile bit TUN3 @ ((unsigned)&OSCTUNE*8)+3;
volatile bit TUN4 @ ((unsigned)&OSCTUNE*8)+4;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned TUN : 5;
struct {
unsigned TUN0 : 1;
unsigned TUN1 : 1;
unsigned TUN2 : 1;
unsigned TUN3 : 1;
unsigned TUN4 : 1;
} OSCTUNEbits @ 0x090;
#endif
// Register: PR2
volatile unsigned char PR2 @ 0x092;
// Register: SSPADD
volatile unsigned char SSPADD @ 0x093;
// Register: SSPMSK
volatile unsigned char SSPMSK @ 0x093; // shared address with SSPADD
volatile unsigned char MSK @ 0x093; // shared address with SSPADD
volatile bit MSK0 @ ((unsigned)&SSPMSK*8)+0;
volatile bit MSK1 @ ((unsigned)&SSPMSK*8)+1;
volatile bit MSK2 @ ((unsigned)&SSPMSK*8)+2;
volatile bit MSK3 @ ((unsigned)&SSPMSK*8)+3;
volatile bit MSK4 @ ((unsigned)&SSPMSK*8)+4;
volatile bit MSK5 @ ((unsigned)&SSPMSK*8)+5;
volatile bit MSK6 @ ((unsigned)&SSPMSK*8)+6;
volatile bit MSK7 @ ((unsigned)&SSPMSK*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned MSK0 : 1;
unsigned MSK1 : 1;
unsigned MSK2 : 1;
unsigned MSK3 : 1;
unsigned MSK4 : 1;
unsigned MSK5 : 1;
unsigned MSK6 : 1;
unsigned MSK7 : 1;
} SSPMSKbits @ 0x093;
#endif
// Register: SSPSTAT
volatile unsigned char SSPSTAT @ 0x094;
volatile bit BF @ ((unsigned)&SSPSTAT*8)+0;
volatile bit UA @ ((unsigned)&SSPSTAT*8)+1;
volatile bit R_nW @ ((unsigned)&SSPSTAT*8)+2;
volatile bit S @ ((unsigned)&SSPSTAT*8)+3;
volatile bit P @ ((unsigned)&SSPSTAT*8)+4;
volatile bit D_nA @ ((unsigned)&SSPSTAT*8)+5;
volatile bit CKE @ ((unsigned)&SSPSTAT*8)+6;
volatile bit SMP @ ((unsigned)&SSPSTAT*8)+7;
volatile bit R @ ((unsigned)&SSPSTAT*8)+2;
volatile bit D @ ((unsigned)&SSPSTAT*8)+5;
volatile bit I2C_READ @ ((unsigned)&SSPSTAT*8)+2;
volatile bit I2C_START @ ((unsigned)&SSPSTAT*8)+3;
volatile bit I2C_STOP @ ((unsigned)&SSPSTAT*8)+4;
volatile bit I2C_DATA @ ((unsigned)&SSPSTAT*8)+5;
volatile bit nW @ ((unsigned)&SSPSTAT*8)+2;
volatile bit nA @ ((unsigned)&SSPSTAT*8)+5;
volatile bit nWRITE @ ((unsigned)&SSPSTAT*8)+2;
volatile bit nADDRESS @ ((unsigned)&SSPSTAT*8)+5;
volatile bit R_W @ ((unsigned)&SSPSTAT*8)+2;
volatile bit D_A @ ((unsigned)&SSPSTAT*8)+5;
volatile bit READ_WRITE @ ((unsigned)&SSPSTAT*8)+2;
volatile bit DATA_ADDRESS @ ((unsigned)&SSPSTAT*8)+5;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned BF : 1;
unsigned UA : 1;
unsigned R_nW : 1;
unsigned S : 1;
unsigned P : 1;
unsigned D_nA : 1;
unsigned CKE : 1;
unsigned SMP : 1;
struct {
unsigned : 1;
unsigned : 1;
unsigned : 1;
unsigned : 1;
unsigned : 1;
unsigned : 1;
unsigned : 1;
unsigned : 1;
struct {
unsigned : 2;
unsigned R : 1;
unsigned : 2;
unsigned D : 1;
struct {
unsigned : 2;
unsigned I2C_READ : 1;
unsigned I2C_START : 1;
unsigned I2C_STOP : 1;
unsigned I2C_DATA : 1;
struct {
unsigned : 2;
unsigned nW : 1;
unsigned : 2;
unsigned nA : 1;
struct {
unsigned : 2;
unsigned nWRITE : 1;
unsigned : 2;
unsigned nADDRESS : 1;
struct {
unsigned : 2;
unsigned R_W : 1;
unsigned : 2;
unsigned D_A : 1;
struct {
unsigned : 2;
unsigned READ_WRITE : 1;
unsigned : 2;
unsigned DATA_ADDRESS : 1;
} SSPSTATbits @ 0x094;
#endif
// Register: WPUA
volatile unsigned char WPUA @ 0x095;
volatile unsigned char WPU @ 0x095;
volatile bit WPUA0 @ ((unsigned)&WPUA*8)+0;
volatile bit WPUA1 @ ((unsigned)&WPUA*8)+1;
volatile bit WPUA2 @ ((unsigned)&WPUA*8)+2;
volatile bit WPUA4 @ ((unsigned)&WPUA*8)+4;
volatile bit WPUA5 @ ((unsigned)&WPUA*8)+5;
volatile bit WPU0 @ ((unsigned)&WPUA*8)+0;
volatile bit WPU1 @ ((unsigned)&WPUA*8)+1;
volatile bit WPU2 @ ((unsigned)&WPUA*8)+2;
volatile bit WPU4 @ ((unsigned)&WPUA*8)+4;
volatile bit WPU5 @ ((unsigned)&WPUA*8)+5;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned WPUA0 : 1;
unsigned WPUA1 : 1;
unsigned WPUA2 : 1;
unsigned : 1;
unsigned WPUA4 : 1;
unsigned WPUA5 : 1;
struct {
unsigned WPU0 : 1;
unsigned WPU1 : 1;
unsigned WPU2 : 1;
unsigned : 1;
unsigned WPU4 : 1;
unsigned WPU5 : 1;
} WPUAbits @ 0x095;
#endif
// Register: IOCA
volatile unsigned char IOCA @ 0x096;
volatile unsigned char IOC @ 0x096;
volatile bit IOCA0 @ ((unsigned)&IOCA*8)+0;
volatile bit IOCA1 @ ((unsigned)&IOCA*8)+1;
volatile bit IOCA2 @ ((unsigned)&IOCA*8)+2;
volatile bit IOCA3 @ ((unsigned)&IOCA*8)+3;
volatile bit IOCA4 @ ((unsigned)&IOCA*8)+4;
volatile bit IOCA5 @ ((unsigned)&IOCA*8)+5;
volatile bit IOC0 @ ((unsigned)&IOCA*8)+0;
volatile bit IOC1 @ ((unsigned)&IOCA*8)+1;
volatile bit IOC2 @ ((unsigned)&IOCA*8)+2;
volatile bit IOC3 @ ((unsigned)&IOCA*8)+3;
volatile bit IOC4 @ ((unsigned)&IOCA*8)+4;
volatile bit IOC5 @ ((unsigned)&IOCA*8)+5;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned IOCA0 : 1;
unsigned IOCA1 : 1;
unsigned IOCA2 : 1;
unsigned IOCA3 : 1;
unsigned IOCA4 : 1;
unsigned IOCA5 : 1;
struct {
unsigned IOC0 : 1;
unsigned IOC1 : 1;
unsigned IOC2 : 1;
unsigned IOC3 : 1;
unsigned IOC4 : 1;
unsigned IOC5 : 1;
} IOCAbits @ 0x096;
#endif
// Register: WDTCON
volatile unsigned char WDTCON @ 0x097;
volatile bit SWDTEN @ ((unsigned)&WDTCON*8)+0;
volatile bit WDTPS0 @ ((unsigned)&WDTCON*8)+1;
volatile bit WDTPS1 @ ((unsigned)&WDTCON*8)+2;
volatile bit WDTPS2 @ ((unsigned)&WDTCON*8)+3;
volatile bit WDTPS3 @ ((unsigned)&WDTCON*8)+4;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned SWDTEN : 1;
unsigned WDTPS : 4;
struct {
unsigned : 1;
unsigned WDTPS0 : 1;
unsigned WDTPS1 : 1;
unsigned WDTPS2 : 1;
unsigned WDTPS3 : 1;
} WDTCONbits @ 0x097;
#endif
// Register: TXSTA
volatile unsigned char TXSTA @ 0x098;
volatile bit TX9D @ ((unsigned)&TXSTA*8)+0;
volatile bit TRMT @ ((unsigned)&TXSTA*8)+1;
volatile bit BRGH @ ((unsigned)&TXSTA*8)+2;
volatile bit SENDB @ ((unsigned)&TXSTA*8)+3;
volatile bit SYNC @ ((unsigned)&TXSTA*8)+4;
volatile bit TXEN @ ((unsigned)&TXSTA*8)+5;
volatile bit TX9 @ ((unsigned)&TXSTA*8)+6;
volatile bit CSRC @ ((unsigned)&TXSTA*8)+7;
volatile bit SENB @ ((unsigned)&TXSTA*8)+3;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned TX9D : 1;
unsigned TRMT : 1;
unsigned BRGH : 1;
unsigned SENDB : 1;
unsigned SYNC : 1;
unsigned TXEN : 1;
unsigned TX9 : 1;
unsigned CSRC : 1;
struct {
unsigned : 3;
unsigned SENB : 1;
} TXSTAbits @ 0x098;
#endif
// Register: SPBRG
volatile unsigned char SPBRG @ 0x099;
volatile bit BRG0 @ ((unsigned)&SPBRG*8)+0;
volatile bit BRG1 @ ((unsigned)&SPBRG*8)+1;
volatile bit BRG2 @ ((unsigned)&SPBRG*8)+2;
volatile bit BRG3 @ ((unsigned)&SPBRG*8)+3;
volatile bit BRG4 @ ((unsigned)&SPBRG*8)+4;
volatile bit BRG5 @ ((unsigned)&SPBRG*8)+5;
volatile bit BRG6 @ ((unsigned)&SPBRG*8)+6;
volatile bit BRG7 @ ((unsigned)&SPBRG*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned BRG0 : 1;
unsigned BRG1 : 1;
unsigned BRG2 : 1;
unsigned BRG3 : 1;
unsigned BRG4 : 1;
unsigned BRG5 : 1;
unsigned BRG6 : 1;
unsigned BRG7 : 1;
} SPBRGbits @ 0x099;
#endif
// Register: SPBRGH
volatile unsigned char SPBRGH @ 0x09A;
volatile bit BRG8 @ ((unsigned)&SPBRGH*8)+0;
volatile bit BRG9 @ ((unsigned)&SPBRGH*8)+1;
volatile bit BRG10 @ ((unsigned)&SPBRGH*8)+2;
volatile bit BRG11 @ ((unsigned)&SPBRGH*8)+3;
volatile bit BRG12 @ ((unsigned)&SPBRGH*8)+4;
volatile bit BRG13 @ ((unsigned)&SPBRGH*8)+5;
volatile bit BRG14 @ ((unsigned)&SPBRGH*8)+6;
volatile bit BRG15 @ ((unsigned)&SPBRGH*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned BRG8 : 1;
unsigned BRG9 : 1;
unsigned BRG10 : 1;
unsigned BRG11 : 1;
unsigned BRG12 : 1;
unsigned BRG13 : 1;
unsigned BRG14 : 1;
unsigned BRG15 : 1;
} SPBRGHbits @ 0x09A;
#endif
// Register: BAUDCTL
volatile unsigned char BAUDCTL @ 0x09B;
volatile bit ABDEN @ ((unsigned)&BAUDCTL*8)+0;
volatile bit WUE @ ((unsigned)&BAUDCTL*8)+1;
volatile bit BRG16 @ ((unsigned)&BAUDCTL*8)+3;
volatile bit SCKP @ ((unsigned)&BAUDCTL*8)+4;
volatile bit RCIDL @ ((unsigned)&BAUDCTL*8)+6;
volatile bit ABDOVF @ ((unsigned)&BAUDCTL*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned ABDEN : 1;
unsigned WUE : 1;
unsigned : 1;
unsigned BRG16 : 1;
unsigned SCKP : 1;
unsigned : 1;
unsigned RCIDL : 1;
unsigned ABDOVF : 1;
} BAUDCTLbits @ 0x09B;
#endif
// Register: ADRESL
volatile unsigned char ADRESL @ 0x09E;
// Register: ADCON1
volatile unsigned char ADCON1 @ 0x09F;
volatile bit ADCS0 @ ((unsigned)&ADCON1*8)+4;
volatile bit ADCS1 @ ((unsigned)&ADCON1*8)+5;
volatile bit ADCS2 @ ((unsigned)&ADCON1*8)+6;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
unsigned ADCS : 3;
struct {
unsigned : 4;
unsigned ADCS0 : 1;
unsigned ADCS1 : 1;
unsigned ADCS2 : 1;
} ADCON1bits @ 0x09F;
#endif
// Special function register definitions: Bank 2
// Register: EEDAT
volatile unsigned char EEDAT @ 0x10C;
volatile unsigned char EEDATA @ 0x10C;
// Register: EEADR
volatile unsigned char EEADR @ 0x10D;
// Register: EEDATH
volatile unsigned char EEDATH @ 0x10E;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 6;
} EEDATHbits @ 0x10E;
#endif
// Register: EEADRH
volatile unsigned char EEADRH @ 0x10F;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
} EEADRHbits @ 0x10F;
#endif
// Register: WPUB
volatile unsigned char WPUB @ 0x115;
volatile bit WPUB4 @ ((unsigned)&WPUB*8)+4;
volatile bit WPUB5 @ ((unsigned)&WPUB*8)+5;
volatile bit WPUB6 @ ((unsigned)&WPUB*8)+6;
volatile bit WPUB7 @ ((unsigned)&WPUB*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
unsigned WPUB : 4;
struct {
unsigned : 4;
unsigned WPUB4 : 1;
unsigned WPUB5 : 1;
unsigned WPUB6 : 1;
unsigned WPUB7 : 1;
} WPUBbits @ 0x115;
#endif
// Register: IOCB
volatile unsigned char IOCB @ 0x116;
volatile bit IOCB4 @ ((unsigned)&IOCB*8)+4;
volatile bit IOCB5 @ ((unsigned)&IOCB*8)+5;
volatile bit IOCB6 @ ((unsigned)&IOCB*8)+6;
volatile bit IOCB7 @ ((unsigned)&IOCB*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 4;
unsigned IOCB4 : 1;
unsigned IOCB5 : 1;
unsigned IOCB6 : 1;
unsigned IOCB7 : 1;
} IOCBbits @ 0x116;
#endif
// Register: VRCON
volatile unsigned char VRCON @ 0x118;
volatile bit VP6EN @ ((unsigned)&VRCON*8)+4;
volatile bit VRR @ ((unsigned)&VRCON*8)+5;
volatile bit C2VREN @ ((unsigned)&VRCON*8)+6;
volatile bit C1VREN @ ((unsigned)&VRCON*8)+7;
volatile bit VR0 @ ((unsigned)&VRCON*8)+0;
volatile bit VR1 @ ((unsigned)&VRCON*8)+1;
volatile bit VR2 @ ((unsigned)&VRCON*8)+2;
volatile bit VR3 @ ((unsigned)&VRCON*8)+3;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned VR : 4;
unsigned VP6EN : 1;
unsigned VRR : 1;
unsigned C2VREN : 1;
unsigned C1VREN : 1;
struct {
unsigned VR0 : 1;
unsigned VR1 : 1;
unsigned VR2 : 1;
unsigned VR3 : 1;
} VRCONbits @ 0x118;
#endif
// Register: CM1CON0
volatile unsigned char CM1CON0 @ 0x119;
volatile bit C1R @ ((unsigned)&CM1CON0*8)+2;
volatile bit C1POL @ ((unsigned)&CM1CON0*8)+4;
volatile bit C1OE @ ((unsigned)&CM1CON0*8)+5;
volatile bit C1OUT @ ((unsigned)&CM1CON0*8)+6;
volatile bit C1ON @ ((unsigned)&CM1CON0*8)+7;
volatile bit C1CH0 @ ((unsigned)&CM1CON0*8)+0;
volatile bit C1CH1 @ ((unsigned)&CM1CON0*8)+1;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned C1CH : 2;
unsigned C1R : 1;
unsigned : 1;
unsigned C1POL : 1;
unsigned C1OE : 1;
unsigned C1OUT : 1;
unsigned C1ON : 1;
struct {
unsigned C1CH0 : 1;
unsigned C1CH1 : 1;
} CM1CON0bits @ 0x119;
#endif
// Register: CM2CON0
volatile unsigned char CM2CON0 @ 0x11A;
volatile bit C2R @ ((unsigned)&CM2CON0*8)+2;
volatile bit C2POL @ ((unsigned)&CM2CON0*8)+4;
volatile bit C2OE @ ((unsigned)&CM2CON0*8)+5;
volatile bit C2OUT @ ((unsigned)&CM2CON0*8)+6;
volatile bit C2ON @ ((unsigned)&CM2CON0*8)+7;
volatile bit C2CH0 @ ((unsigned)&CM2CON0*8)+0;
volatile bit C2CH1 @ ((unsigned)&CM2CON0*8)+1;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned C2CH : 2;
unsigned C2R : 1;
unsigned : 1;
unsigned C2POL : 1;
unsigned C2OE : 1;
unsigned C2OUT : 1;
unsigned C2ON : 1;
struct {
unsigned C2CH0 : 1;
unsigned C2CH1 : 1;
} CM2CON0bits @ 0x11A;
#endif
// Register: CM2CON1
volatile unsigned char CM2CON1 @ 0x11B;
volatile bit C2SYNC @ ((unsigned)&CM2CON1*8)+0;
volatile bit T1GSS @ ((unsigned)&CM2CON1*8)+1;
volatile bit MC2OUT @ ((unsigned)&CM2CON1*8)+6;
volatile bit MC1OUT @ ((unsigned)&CM2CON1*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned C2SYNC : 1;
unsigned T1GSS : 1;
unsigned : 4;
unsigned MC2OUT : 1;
unsigned MC1OUT : 1;
} CM2CON1bits @ 0x11B;
#endif
// Register: ANSEL
volatile unsigned char ANSEL @ 0x11E;
volatile bit ANS0 @ ((unsigned)&ANSEL*8)+0;
volatile bit ANS1 @ ((unsigned)&ANSEL*8)+1;
volatile bit ANS2 @ ((unsigned)&ANSEL*8)+2;
volatile bit ANS3 @ ((unsigned)&ANSEL*8)+3;
volatile bit ANS4 @ ((unsigned)&ANSEL*8)+4;
volatile bit ANS5 @ ((unsigned)&ANSEL*8)+5;
volatile bit ANS6 @ ((unsigned)&ANSEL*8)+6;
volatile bit ANS7 @ ((unsigned)&ANSEL*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned ANS0 : 1;
unsigned ANS1 : 1;
unsigned ANS2 : 1;
unsigned ANS3 : 1;
unsigned ANS4 : 1;
unsigned ANS5 : 1;
unsigned ANS6 : 1;
unsigned ANS7 : 1;
} ANSELbits @ 0x11E;
#endif
// Register: ANSELH
volatile unsigned char ANSELH @ 0x11F;
volatile bit ANS8 @ ((unsigned)&ANSELH*8)+0;
volatile bit ANS9 @ ((unsigned)&ANSELH*8)+1;
volatile bit ANS10 @ ((unsigned)&ANSELH*8)+2;
volatile bit ANS11 @ ((unsigned)&ANSELH*8)+3;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned ANS8 : 1;
unsigned ANS9 : 1;
unsigned ANS10 : 1;
unsigned ANS11 : 1;
} ANSELHbits @ 0x11F;
#endif
// Special function register definitions: Bank 3
// Register: EECON1
volatile unsigned char EECON1 @ 0x18C;
volatile bit RD @ ((unsigned)&EECON1*8)+0;
volatile bit WR @ ((unsigned)&EECON1*8)+1;
volatile bit WREN @ ((unsigned)&EECON1*8)+2;
volatile bit WRERR @ ((unsigned)&EECON1*8)+3;
volatile bit EEPGD @ ((unsigned)&EECON1*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned RD : 1;
unsigned WR : 1;
unsigned WREN : 1;
unsigned WRERR : 1;
unsigned : 3;
unsigned EEPGD : 1;
} EECON1bits @ 0x18C;
#endif
// Register: EECON2
volatile unsigned char EECON2 @ 0x18D;
// Register: PSTRCON
volatile unsigned char PSTRCON @ 0x19D;
volatile bit STRA @ ((unsigned)&PSTRCON*8)+0;
volatile bit STRB @ ((unsigned)&PSTRCON*8)+1;
volatile bit STRC @ ((unsigned)&PSTRCON*8)+2;
volatile bit STRD @ ((unsigned)&PSTRCON*8)+3;
volatile bit STRSYNC @ ((unsigned)&PSTRCON*8)+4;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned STRA : 1;
unsigned STRB : 1;
unsigned STRC : 1;
unsigned STRD : 1;
unsigned STRSYNC : 1;
} PSTRCONbits @ 0x19D;
#endif
// Register: SRCON
volatile unsigned char SRCON @ 0x19E;
volatile bit PULSR @ ((unsigned)&SRCON*8)+2;
volatile bit PULSS @ ((unsigned)&SRCON*8)+3;
volatile bit C2REN @ ((unsigned)&SRCON*8)+4;
volatile bit C1SEN @ ((unsigned)&SRCON*8)+5;
volatile bit SR0 @ ((unsigned)&SRCON*8)+6;
volatile bit SR1 @ ((unsigned)&SRCON*8)+7;
#ifndef _LIB_BUILD
volatile union {
struct {
unsigned : 2;
unsigned PULSR : 1;
unsigned PULSS : 1;
unsigned C2REN : 1;
unsigned C1SEN : 1;
unsigned SR : 2;
struct {
unsigned : 6;
unsigned SR0 : 1;
unsigned SR1 : 1;
} SRCONbits @ 0x19E;
#endif
#endif
// Version : 1.0
// Compiler : HITECT PICC-Lite Version 9.83
// IDE : Microchip MPLAB IDE v8.70
#include <htc.h>
__CONFIG(FOSC_INTRCIO & WDTE_OFF & PWRTE_ON & MCLRE_ON & CP_OFF & CPD_OFF & BOREN_OFF & IESO_OFF & FCMEN_OFF);
pulse_max=0;
pulse_top=0;
void main(void)
int ldr_diff;
pulse_max=0;
pulse_top=0;
/* Initial ADC */
OPTION_REG = 0b00000000; // 1:2 Prescaller
for(;;) {
GO_DONE=1; // initiate conversion on the channel 4
while(GO_DONE) continue; // Wait for ldr_left conversion done
GO_DONE=1; // initiate conversion on the channel 5
while(GO_DONE) continue; // Wait for ldr_right conversion done
} else {
} else {
/* EOF: servo.c */
Build C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\pradeep_k_b for device 16F690
Using driver C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe
Make: The target "C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\main.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 "C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\main.c" -q --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" -opradeep_k_b.cof -mpradeep_k_b.map --summary=default --output=default main.p1 --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode) V9.83
Copyright (C) 2011 Microchip Technology Inc.
Serial number: HCPICP-XXXXXXXXX (PRO)
Memory Summary:
Program space used 88h ( 136) of 1000h words ( 3.3%)
Data space used Bh ( 11) of 100h bytes ( 4.3%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Configuration bits used 1h ( 1) of 1h word (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Loaded C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\pradeep_k_b.cof.
********** Build successful! **********
"Build C:\Users\PRAMOD\Desktop\DElete it\hi for device 16F690
Using driver C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe
Executing: "C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe" -ohi.cof -mhi.map --summary=default --output=default --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH PICC-Lite COMPILER (Microchip PICmicro) V9.60PL1
Copyright (C) 1984-2007 HI-TECH SOFTWARE
Error [939] ; . no file arguments
********** Build failed! **********
then i did an attempt with mikroC pro,then got another error message "0 1 mikroCPIC1618.exe -MSF -DBG -pP16F690 -DL -O11111114 -fo8 -N"C:\Users\PRAMOD\Desktop\DElete it\new.mcppi" -SP"C:\Users\Public\Documents\Mikroelektronika\mikroC PRO for PIC\defs\" -SP"C:\Users\Public\Documents\Mikroelektronika\mikroC PRO for PIC\Uses\P16\" -SP"C:\Users\PRAMOD\Desktop\DElete it\" "new.c" "hamming_test.c" "__Lib_Math.mcl" "__Lib_MathDouble.mcl" "__Lib_System.mcl" "__Lib_Delays.mcl" "__Lib_CType.mcl" "__Lib_CString.mcl" "__Lib_CStdlib.mcl" "__Lib_CMath.mcl" "__Lib_Conversions.mcl" "__Lib_Sprinti.mcl" "__Lib_Sprintl.mcl" "__Lib_Time.mcl" "__Lib_Trigonometry.mcl" "__Lib_Button.mcl" "__Lib_Keypad4x4.mcl" "__Lib_Manchester.mcl" "__Lib_OneWire.mcl" "__Lib_PS2.mcl" "__Lib_Sound.mcl" "__Lib_SoftI2C.mcl" "__Lib_SoftSPI.mcl" "__Lib_SoftUART.mcl" "__Lib_ADC_A_B.mcl" "__Lib_EEPROM.mcl" "__Lib_FLASH_R.mcl" "__Lib_PWM_c5.mcl" "__Lib_SPI_b64c7.mcl" "__Lib_UART_b75.mcl" "__Lib_PortExpander.mcl" "__Lib_CANSPI.mcl" "__Lib_GlcdFonts.mcl" "__Lib_Glcd.mcl" "__Lib_LcdConsts.mcl" "__Lib_Lcd.mcl" "__Lib_RS485.mcl" "__Lib_S1D13700.mcl" "__Lib_SPIGlcd.mcl" "__Lib_SPILcd.mcl" "__Lib_SPILcd8.mcl" "__Lib_SPIT6963C.mcl" "__Lib_EthEnc28j60.mcl" "__Lib_TFT.mcl" "__Lib_TouchPanel_TFT.mcl" "__Lib_EthEnc24j600.mcl" "__Lib_TouchPanel.mcl"
0 1139 Available RAM: 240 [bytes], Available ROM: 4096 [bytes]
0 304 C:/Users/PRAMOD/Desktop/DElete it/new.c:10: error: Can't open include file "htc.h"
0 304 #include <htc.h>
0 304 1 error in preprocessor.
0 304 C:/Users/PRAMOD/Desktop/DElete it/hamming_test.c:10: error: Can't open include file "htc.h"
0 102 Finished (with errors): 15 Jun 2012, 09:02:12 new.mcppi
Build C:\Users\PRAMOD\Desktop\DElete it\helo for device 16F690
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" -ohelo.cof -mhelo.map --summary=default --output=default --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Licensed for evaluation purposes only.
This licence will expire on Sat, 04 Aug 2012.
Build C:\Users\PRAMOD\Desktop\DElete it\hello2\my first for device 16F690
Make: The target "C:\Users\PRAMOD\Desktop\DElete it\hello2\hai.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 "C:\Users\PRAMOD\Desktop\DElete it\hello2\hai.c" -q --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" "-omy first.cof" "-mmy first.map" --summary=default --output=default hai.p1 --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Memory Summary:
Loaded C:\Users\PRAMOD\Desktop\DElete it\hello2\my first.cof.
sir..but the code is only 1KB..???...
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\htre.mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Fri Jun 15 12:17:08 2012
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Users\PRAMOD\Desktop\important\delete\htre.mcs".
Clean: Done.
Executing: "C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe" /q /p16F628A "enc-044.asm" /l"enc-044.lst" /e"enc-044.err" /d__DEBUG=1
(902) no chip name specified; use "PICC --CHIPINFO" to see available chip names
Halting build on first failure as requested.
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\htre.mcp' failed.
BUILD FAILED
; Filename: encoder.asm *
; Date: *
; File Version: *
;NOTES
;encoder v4.2
;HISTORY
; 040-20050131 4/8-channel encoder for 16F630
; 041-20050213
; 042-20050217 modify transmission repetition algorithm
; 043-20050227 use IR medium with irmtxv4 library
; 044-20090531 adapt 042-20050227 to the pic16f628
list p=16f628
__CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF & _BODEN_OFF
; toggle or momentary mode, 8 channels
#define MODE_CH8
; ON/OFF latched mode, 4 channels
;#define MODE_CH4
#include <p16F628.inc>
#include <mtxv4.inc>
variables UDATA
; RAM registers
tcnt RES 1
rcnt RES 1
cod RES 1
prevcod RES 1
cod0 RES 1
rowstate RES 1
startup CODE 0
goto main
nop
nop
nop
retfie
prog CODE
main ; program starts here
clrf PORTA
clrf PORTB
clrf TMR0
BANKSEL TRISA
movlw 0
movwf TRISA
movlw 0xf0
movwf TRISB
bcf OPTION_REG, PSA
clrwdt
clrf OPTION_REG
clrwdt
BANKSEL PORTA
movlw 7
movwf CMCON
movlw (1<<RBIE); RB4-7 int on change enable
movwf INTCON
call mtx_init
clrf mtx_buffer
clrf tcnt
loop0 clrf (mtx_buffer+1)
movlw 0xff
movwf prevcod ; no button was pressed in the previous scan
movlw 0xfc ;ca,cb=0,cj=1
movwf PORTB
movlw 0xf0
tris PORTB
movf PORTB, W
bcf INTCON, RBIF
sleep
loop clrf cod
movlw 0xfe
tris PORTB ; select colA (RB0)
clrf PORTB
#ifdef MODE_CH8
clrw
#endif
#ifdef MODE_CH4
movlw 0x20
#endif
call scan
movlw 0xfd
tris PORTB ; select colB (RB1)
#ifdef MODE_CH8
movlw 0x04
#endif
#ifdef MODE_CH4
movlw 0x30
#endif
call scan
movf cod, W
bz loop2 ; if no buton is pressed, skip
subwf prevcod, W ; if the same button is pressed, skip
bz loop2
movf cod, W
movwf prevcod ; a new button is pressed - rcnt=3
movwf (mtx_buffer+1)
movlw 3
movwf rcnt
movlw 0x40 ; new button - new transmission
addwf tcnt, F
loop2 movlw 0xf7
tris PORTB ; select ID (RB3)
call scanid
movf cod0, W
movwf (mtx_buffer)
loop3 movf (mtx_buffer+1), W
andlw 0x3f
iorwf tcnt, W
call mtx_send
movf rcnt, W
bz loop_done
decfsz rcnt, F
goto loop
loop_done movf cod, W
btfsc STATUS, Z
goto loop0 ; no button was pressed, go sleep
; if the same button is being hold, repeat the transmission
goto loop
scan movwf cod0
;movlw 0xc0
scandelay ;addlw 1
;bnz scandelay
movlw 0xf0
andwf PORTB, W
movwf rowstate
incf cod0, F
btfss rowstate, 4
goto pressed
incf cod0, F
btfss rowstate, 5
goto pressed
incf cod0, F
btfss rowstate, 6
goto pressed
incf cod0, F
btfss rowstate, 7
goto pressed
retlw 0
pressed movf cod0, W
movwf cod
return
scanid clrf cod0
clrw
scandelay2 addlw 1
bnz scandelay2
movlw 0xf0
andwf PORTB, W
movwf rowstate
btfss rowstate, 7
bsf cod0, 3
btfss rowstate, 6
bsf cod0, 2
btfss rowstate, 5
bsf cod0, 1
btfss rowstate, 4
bsf cod0, 0
return
end
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\hm.mcp' started.
Fri Jun 15 13:52:43 2012
Clean: Deleted file "C:\Users\PRAMOD\Desktop\important\delete\hm.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "enc-044.asm" /l"enc-044.lst" /e"enc-044.err" /d__DEBUG=1
Message[301] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\P16F628.INC 35 : MESSAGE: (Processor-header file mismatch. Verify selected processor.)
Error[105] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 32 : Cannot open file (Include File "mtxv4.inc" not found)
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 34 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 43 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 50 : Directive only allowed when generating an object file
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 59 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 61 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 63 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 65 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 74 : Symbol not previously defined (mtx_init)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 75 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 78 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 84 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 91 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 101 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 117 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 125 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 128 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 130 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 133 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 135 : Symbol not previously defined (mtx_send)
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\hm.mcp' failed.
Fri Jun 15 13:52:44 2012
BUILD FAILED
list p=16f628[COLOR="#FF0000"]a[/COLOR]
#define MODE_CH8
;#define MODE_CH4
#include <p16F628[COLOR="#FF0000"]A[/COLOR].inc>
#include mtxv4.inc
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\cat.mcp' started.
Fri Jun 15 17:21:21 2012
Clean: Deleted file "C:\Users\PRAMOD\Desktop\important\delete\cat.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628 "enc-044.asm" /l"enc-044.lst" /e"enc-044.err" /d__DEBUG=1
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\MTXV4.INC 14 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\MTXV4.INC 15 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 34 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 43 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 50 : Directive only allowed when generating an object file
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 59 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 61 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 63 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 65 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 74 : Symbol not previously defined (mtx_init)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 75 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 78 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 84 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 91 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 101 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 117 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 125 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 128 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 130 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 133 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 135 : Symbol not previously defined (mtx_send)
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\cat.mcp' failed.
Fri Jun 15 17:21:22 2012
BUILD FAILED
