can this cmos circuit operate??
t1990
Newbie level 3
hi
i am just wondaring if circuit like this can operate by connecting two inverters in series
why do you need two inverters for the same input ?
and you only need two outputs
not for a certain reason ,just as an example. can this work as two separated inverter or some technical problems will rise
what is the high level of IN , is it VDD or 2xVDD?
Is the center of the two inverter fixed (connected) to a VDD supply (like in your picture)?
regards
The NMOS may not open even if high voltage. Also the bulk/substrate voltage may matter here. The topmost pmos may be reverse -biased
No this wont . You need to flip the lower circuit and instead of VDD in the middle you need to provide VSS for common nmos ground. then this will work
